Old 12-12-2023, 05:04 PM
JudahThadeo JudahThadeo is offline
Default All AAX plugins missing PT2023.12
I've re-installed Pro Tools 2023.12 after not having used it for 2 years. In between I worked with Ableton and was able to simply run my Soundtoys, Waves, Native Instruments plugins.
Now I know with the whole apple Silicon issues we were supposed to run it in Rosetta but it seems like I'm having a different issue. The Apple Silicon Pro Audio Compatibility Chart issues my plugins as natively working, and NI and Soundtoys state on their website that it they're compatible with PT2023 as well.
What I'm wondering is if I should re-install these plugins since they were installed before Pro tools was installed? Or could it be because I installed this latest version of PT which might have problems?
I'm running on MacBook Pro (16-inch, 2021)
Apple M1 Pro
macOS Monterey 12.5
All help is welcome
Old 12-12-2023, 05:34 PM
Default Re: All AAX plugins missing PT2023.12
Ok so apparently a reinstallation created the aax files in the Avid folder so that solved the issue
Old 12-18-2023, 03:24 PM
skylar_battles skylar_battles is offline
Can you specify more? Trying to solve an issue I am having.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 12-18-2023, 04:58 PM
Not sure exactly what happened there, but a reisntallation of Pro Tools can normally only update the core plugins included with Pro Tools itself. Maybe you had a corrupted plugin cache that got recreated (which trashing prefs will also do) here that solved the problem.
When you suspect problems related to Apple Silicon and plugins support etc. a great thing to do is run a plugin report using Pete Gate's free PT Prefs 2 program (https://petegates.com/pgptprefs.html) and see what is actually installed in the plugin folder and if they support Apple Silicon (i.e. are marked Universal) or are intel only (marked x64). And PT Prefs 2 also makes it easy to trash prefs which may just magically fix many issues to start with.
...and...
Uh no. Starting with Pro Tools 2023.3 (and Pro Tools 2022.12 with beta Apple Silicon Support) there is official support for Apple Silicon native, and you should aim to run that without Rosetta (the default behavior) unless you have legacy plugins that does not support Apple Silicon native. By now many plugins do, but not all.
And be careful about plugin vendors who say things like "supports Apple Silicon" meaning it runs OK under Rosetta and actually having native Apple Silicon ports of their plugins. Some plugin vendors are just awful how they talk about this. Again, just use PT Prefs 2 to check.
HTML code is On
PT2023 and Mac Studio disappointments juh Pro Tools 35 01-21-2024 06:08 AM
PT2023.9 on best on Monterey or Ventura? sco macOS 10 10-23-2023 06:40 AM
PT2023.3 / why pan act as volume? senghor Pro Tools 3 10-22-2023 01:47 PM
missing plugins - missing subscription pt12 jazztronauts Pro Tools 12 0 02-23-2016 09:38 AM
Plugins missing in drop down list, but in plugins folder ?? mixingmadness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-12-2007 10:27 AM
