What\'s best way to hook up a turn table?
so I recently just bought a turn table and I am trying to hook it up to my m-box but I am getting a huge amount of ground noise. Whats the problem. My signal path is RCA to phono bbe preamp (not a mixer obviously) to "Tip-Common" cable that split to a Y to DI's in the M-box. HOW DO i GET RID OF THIS GROUND NOISE. It is also possible that I set up the turn tables wrong. I am very inexperienced with vinal so any comments will help even if they seem extremely obvious. Thanks
Re: What\'s best way to hook up a turn table?
Has the turntable got a ground wire? If so just connect it to a radiator or the metal casing of a piece of equipment. Ive only really had experience with Technics turntables and I know that these have ground wires.
Wes |
I'm not familiar with the pre-amp you mention, are you using a specfic phono pre-amp?
This will be necessary to make it work. There are lots of cheap DJ mixers out there with these built in, or you can buy a preamp specifically for this. http://www.sweetwater.com/store/detail/DeeJayPre/ Hope that helps.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
Does your turntable have a pre-amp built in? It may, my wife bought one not so long ago which does. Check the doc's which came with it.
Dual 2.0 G5, 10.4.6, PTLE 7.1, 002R |
Also, if your cartridge is properly grounded, buzz should be much less of an issue. |
So I hooked up the grounding cable and got rid of the noise. DUH. Now for another maybe less so obvious question what is the best way to record it into protools. I have it going though the DI's but that still leaves an mbox imprint (converters and sound of the preamp) is there a way to record it directly digital? maybe utalizing S/PDIF? Thanks hopefully there is a super obvious anser to this too.
What Do I need to hook Up My Turn Tables... | Haystack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-22-2005 06:59 PM |
hookin a turn table to a Mbox to sample | BxThree1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-29-2004 02:30 AM |
Digi001 and mix table ? | saltine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-08-2003 12:26 AM |
$60,000.00 On the table?!?!?!? | sugarfuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 08-27-2002 07:30 AM |
Re: Delay -> Table | javier | Tips & Tricks | 2 | 10-31-1999 10:18 AM |
