Old 11-03-2021, 03:56 PM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: Komplete Kontrol Host Integration
https://support.native-instruments.c...MPLETE-KONTROL
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 11-03-2021, 04:06 PM
randb1 randb1 is offline
Glad the fix worked, I had trashed those before for a related KK problem but hadn’t realized that the last update to PT put them back. Will have to remember to check in the future after an update to PT. Had no Idea they were Facebook plugins, why would they be needed?
Old 11-03-2021, 04:31 PM
ReynaldoPena ReynaldoPena is offline
F***K YEAH!!!!!!
We got it to work! Thanks team!!
Originally Posted by randb1 View Post
Hi Reynaldo,
I've been following your post as I have an S88 MKII keyboard with exactly the same problem that you have and I found a solution that worked for me and hopefully it will for you too. I discovered that Pro Tools, upon launching, was loading a plugin that was interfering with my KK keyboard. That plugin is has 5 instances that start with FB360 and have different plugins associated with it. I simply went into the PT plugins folder: Mac HD/Library/Application Support/Avid/Audio/Plugins and then highlighted all of the plugins that were Labeled FB360 and moved them out of the plugins folder to my desktop. That fixed my problem! I'm now able to open Komplete Kontrol on an instrument track in PT and all of the buttons, knobs, etc. work and now it will start and stop playback of PT!. I think the FB360 plugins are part of Pro Tools because I never purchased them so they must be built in and I have no use for them so, I'm good to go. I sincerely hope this works for you too. Best of luck!!
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-04-2021, 12:31 PM
PhiBee's Avatar
PhiBee PhiBee is offline
Hi<
Sorry nothing worked for me with my A61.
I can use it as a simple control keyboard but without the new features announced.
- PT Ultimate 2021.10 OK
- NI products up-to-date (especially Komplete Kontrol)
- last firmware for the A61 OK
- deleted those nasty FB plugins (as we had to do a year ago. Though it was ok now)
- restarted ProTools OK
- choose the right peripheral OK
- restarted (again) ProTools OK
- Created a new session OK
- .. etc
Still does not work.
Posted on the NI forum, waiting for an answer (crossed fingers ON).
An idea ?
WIP house Prod - home studio
iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61
STUDIO PRO Post-prod
MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic.
Old 11-04-2021, 01:18 PM
I'm still unable to use the transport and such as advertised in the new Pro Tools.
No problem using the Komplete Kontrol plugin. You'll need to delete those FB plugins to get it running.
Stephen
  #16
Old 11-04-2021, 01:23 PM
Turns out you cannot use any Kontrol keyboard as originally stated
"Pro Tools with Native Instruments Komplete Kontrol
Native Instruments Komplete Kontrol users can now control many Pro Tools functions directly from their Komplete Kontrol S-series mk2, A-series, or M32 keyboard. Supported functions include transport, session navigation, and basic mixer controls. In addition, the Komplete Kontrol plug-in controls will be linked to the track selection. This integration enables a highly streamlined music creation workflow by minimizing the need to move between your keyboard and computer."
https://avid.secure.force.com/pkb/ar...-Release-Notes
Stephen
  #17
Old 11-04-2021, 01:34 PM
massivekerry's Avatar
massivekerry massivekerry is offline
Stephen
Well at least they edited THAT doc. The Release-Day page didn't stipulate that, and the What's New and Reference Guide PDFs in the Installer package (which I just re-downloaded to confirm as of today) don't make that distinction either. (Tho the What's New now says "Supported" keyboards, without indicating which those are)
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
  #18
Old 11-04-2021, 06:30 PM
bzone bzone is offline
The latest keyboard will work, not the first generation. No problems here with Big Sur and 21.10 on a 7.1 Mac Pro and HDX system.
  #19
Old 11-04-2021, 06:33 PM
Also in 2019 NI stated the first generation key boards would not function on 2019 and Catalina. You need the second generation.
  #20
Old 11-05-2021, 03:41 AM
NI are obviously keen for everyone to upgrade their hardware
Stephen
Avid Gobbler integration Sonopolis General Discussion 17 01-23-2013 05:10 PM
Avid Mojo and Pro Tools 7.1 HD Integration jill_m Post - Surround - Video 6 08-02-2006 09:33 AM
AVID Express DV integration with HD3 DaveCarlock Pro Tools TDM Systems (Mac) 13 08-13-2002 12:02 AM
avid and protools LE integration Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-24-2002 12:37 AM
