Old 03-25-2011, 09:03 AM
Nuno_F Nuno_F is offline
Unhappy 002 Rack and PT9.0.2
Hello all,
I just spent the last two days trying to bounce a mix of a track recorded at 88.2. All the time I kept getting either CPU overload errors or Lost communication with interface errors.
I decided to reduce the RTAS load in the session, same problem. Converted the session to 44.1, same problem. I updated the drivers once again, same problem.
Finally I decided to use my PODxt as interface and the mix bounced fine.
Any tips on what can be wrong? Any place in the Boston are where I can take my 002 to be checked?
Old 03-26-2011, 05:30 AM
Default Re: 002 Rack and PT9.0.2
Anyone?
Old 03-26-2011, 11:17 AM
Dorian Green Dorian Green is offline
How many processors are you using?
H/W Buffer size?
Cache Levels?
Working with Apple or PC?
Which OS ?
Green Room Studios, France
Mac Book Pro i7 15"4 Mac OSX 10.6.6
PT 9.0.2
DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate.
PTLE 8.0.4
002R Unit and MBox Mini
SSL XLogic Alpha Channel.
SPL Goldmike valve Preamp.
DBX Analog Compressors, Gate and Eq.
Monster Cables
Home made & Neutrik Patchbay.
Brauner, Shure, Seinnheiser and T.Bone mikes.
Tannoy 8D Active monitors.
Old 03-27-2011, 08:29 AM
trondned trondned is offline
Same problem here.
Trond
PT 9.0.2
Digi002R
OsX 10.6 (mac)
Trond Nedberg
Nedberg Audio
Kongensgate 16
0153 Oslo
Norway
Nedberg Audio
[email protected]
Old 03-27-2011, 09:43 AM
Mac OSX 10.6.5
PT 9.0.2
Using 8 processors with 99%
10 GB memory
Shoudn't be an issue, specially because I bounced it fine using the PODxt as interface.
Old 03-27-2011, 09:44 AM
Oh, and maximum buffer.
Old 03-27-2011, 01:54 PM
Leneson Leneson is offline
Yeah I've been having nonstop error with disconnects and what not from my Digi002 Rack, even when no audio is playing PT9 just locks up. Now that you mention it, when I select my computer as the interface it plays just fine, I just can't hear it because my computer has no speakers lol.
Old 03-27-2011, 01:58 PM
I also get a ton of of CPU overload errors (-6101), even at the highest buffer size and im on a 16core intel mac. I've also set the processor limit to 14 to leave one for the SD2.0 VI
Old 03-29-2011, 06:13 AM
Has anyone found a solution? Thanks!
Old 03-31-2011, 09:59 AM
quantise quantise is offline
Current wisdom says that it's a good idea to run at one less processor than you have in total. So, backing off to 7 in your case would be worth a try.
John
PT 2021.12 Native 2x Universal Audio Apollo 8p and Apollo 8
Mac Studio. M1 Max. OS Monterey 12.3
Avid S3 and Avid Dock. Dynaudio BM5's.
need help setting up protools 8 le with motif rack and trition rack(so newby to this) BeatBoy19 MIDI 0 06-01-2011 10:38 PM
Advice for Foot Controller and Rack/Case for Eleven Rack? udamann88 Eleven Rack 19 03-08-2011 06:24 PM
THE FOOT CONTROLLER for the Eleven Rack and any other rack modeler for that matter.. vkaxeman Eleven Rack 3 01-19-2011 04:13 AM
Record form Mix Rack & Stage Rack into 1 Pro Tools system kwz VENUE Live Sound Systems 3 01-04-2011 12:10 PM
Major comp. problem - considering reverting to 002 rack instead 003 rack, good move? Tbassist4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-15-2009 04:20 PM
