Old 01-21-2011, 08:48 AM
Dorian Green Dorian Green is offline
Default Couple of tips for PT9
Maybe some of you already know that...
Once Protools is launched and opened...you can REMOVE the iLok which makes an available USB Port. Protools won't quit.
Also I've found a great app on the iPhone App Store called AirPhones.It basically turns your iPhone into a "wireless soundcard receiver". It appears in the Playback Engine > Device.
With the proper connections you can turn any amplified Stereo into monitors, or you can use it to get a wireless headphone for your protools.
I've read you can even set the software to use it without WIFI network (directly from the computer to the iPhone). But I can't tell if it works with PC.
Hope it will help
Green Room Studios, France
Mac Book Pro i7 15"4 Mac OSX 10.6.6
PT 9.0.2
DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate.
PTLE 8.0.4
002R Unit and MBox Mini
SSL XLogic Alpha Channel.
SPL Goldmike valve Preamp.
DBX Analog Compressors, Gate and Eq.
Monster Cables
Home made & Neutrik Patchbay.
Brauner, Shure, Seinnheiser and T.Bone mikes.
Tannoy 8D Active monitors.
Old 01-21-2011, 09:40 AM
KMcK KMcK is offline
Default Re: Couple of tips for PT9
Yes, but if you then try and instantiate any plug-ins that require iLok authorization, you'll have to insert it again, so might as well leave it plugged in unless you never use any plug-ins.
Old 01-21-2011, 09:43 AM
Dism Dism is offline
Not true.
Pro Tools will periodically do an authorization check, particularly if you switch sessions. It's not like how most plugins are fine if you pull the iLok. There's no point freeing up the port, because you're going to have to swap it back again anyway.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-21-2011, 10:12 AM
daeron80 daeron80 is offline
Airphones is very good to know about. Thanks. That will come it handy in several ways I can think of.
[EDIT:] Oh, shoot. XP/Vista x32 only.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 01-21-2011, 10:40 AM
Yep...
Didn't know PT would make periodic checks...Good to know thanx.
I didn't think about iLok authorized plugins but I thought the checking was made only once during PT start up (when it lists all dpms...)...and as I don't have any plugins of that sort (only digirack)...
Tough...!
At least my second tip is more relevant...
PT 9.0.2
PTLE 8.0.4
Monster Cables
Old 01-21-2011, 10:44 AM
soundboy35 soundboy35 is offline
More than checks for the iLok.... mine told me it was gong to automatically save the session and close it. Even after I put the iLok back in, it still saved & closed!
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Couple of HDX Q's iMartin Pro Tools HDX & HD Native Systems (Mac) 6 04-03-2012 01:46 PM
a couple VIs, new (to me) ejwells Virtual Instruments 1 05-11-2006 12:32 PM
couple of 5.1.3 questions... Sonicvalley Pro Tools TDM Systems (Mac) 5 03-23-2005 11:08 AM
Couple of 001 questions bean438 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-22-2005 10:16 PM
couple o newbie q's - fredouli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-10-2004 05:54 AM
