Old 12-30-2008, 03:30 PM
gbross gbross is offline
Default What happened to the 7.* compressors in PT 8?
I am running PT 8 LE on an XP machine.
Where are the "standard" compressors that I have been using for years? These are the compressor plug-ins that came with PT 6.* LE and PT 7.* LE.
Can I download them from somewhere? Where? Will they work with PT8?
Old 12-30-2008, 03:48 PM
wolfskin wolfskin is offline
Default Re: What happened to the 7.* compressors in PT 8?
All digirack (stock) plug-ins are automatically installed with the PT8 installer.
Which 'standard' compressor are you looking for specifically?
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 12-30-2008, 03:58 PM
SeedGuy SeedGuy is offline
They can be found in the unused plug-ins folder. \Program Files\Common Files\Digidesign\DAE\Plug-ins (unused)\
Thats if you're talking about EQ II and Dynamics II
I think I read somewhere on the DUC that they're not supported by DIGI anymore, but can obviously still be used. May be wrong however.
Old 12-30-2008, 11:05 PM
spy2520 spy2520 is offline
all the dynamics 3 plug-ins work for me on xp. Maybe the older ones are unsupported.
Old 12-31-2008, 11:00 AM
DigiTechSupt's Avatar
That is correct - they were phased out with 7.4. Only the 'III' versions are supported in 7.4 and higher.
Avid Audio Tech Support
Support FAQ
Old 12-31-2008, 12:27 PM
sean shannon sean shannon is offline
What sucks about that is that those were useful utility plugins that used almost no CPU, and did the job just fine. Sometimes I need a simple highpass filter, for example, and don't need the flashy GUI of the EQIII, and the old EQII was a perfect, no-nonsense plugin. I also used the Compressor more than about any other plugin. It just worked, with extremely low CPU usage. Especially useful on my laptop.
Why would the decision be made to un-"support" a useful Digi plugin? They are used in a ton of sessions, and opening one will now involve replacing all of those. Why? Tired of the look?
Check your mix in mono.
www.mixingtheband.com
Old 12-31-2008, 01:31 PM
Because they take time and resources to support - time and resources that could be used for other things.
Support FAQ
Old 01-01-2009, 12:27 PM
Oh. I'm not a programmer, and the plug was already written, so I assumed it was already integrated. I was unaware that it would take extra time and resources to "support" those. That's too bad, they were quick and easy in a high-paced session. Thanks for the clarification.
Old 01-01-2009, 01:25 PM
Digi spent time creating updated EQ and dynamics plugs, which sound much better than the old ones, just as simple to use, and still use very little resources, so I see no problem here!?
If you have older sessions with the plugs then you can still use them.
Old 01-01-2009, 03:48 PM
pennard pennard is offline
Banned
Originally Posted by sean shannon View Post
What sucks about that is that those were useful utility plugins that used almost no CPU, and did the job just fine. Sometimes I need a simple highpass filter, for example, and don't need the flashy GUI of the EQIII, and the old EQII was a perfect, no-nonsense plugin. .....
Have you tried the AIR KiLLeq
using compressors? bonzerboy General Discussion 2 11-04-2012 03:54 AM
Compressors in PT Wango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-03-2009 12:20 PM
compressors Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-28-2006 11:52 AM
New URS Compressors George Ware Pro Tools TDM Systems (Win) 1 10-08-2005 05:30 AM
Wow!!! URS Compressors!!!! Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-07-2005 05:39 AM
