Old 08-05-2003, 02:04 PM
DigiTechSupt's Avatar
Default Re: BAD CORE CARDS?
Hello,
It could be a faulty interface cable as well. Do you have the 3rd and 4th interface connected to the same card from one DigiLink cable? You may want to try swapping the interface cable from the Core card to the Process card to see if the problem follows the cable. Also, try swapping out the loop sync BNC cables going to and from those interfaces.
If the problem persists you can setup an RA by contacting tech support at 650-731-6100. If the system is in warranty there will be no charge to repair the card or cable.
If you would like information about our premium support contracts contact our Presales department:
http://www.digidesign.com/aboutus/contact/
Mike
Avid Audio Tech Support
Support FAQ
Old 08-05-2003, 07:59 PM
Benjiman Benjiman is offline
Thanks, I ran tests on all the cards individually and three of the four failed. Even though I have heard the digi card test is not foolproof (I actually ran the test's 10 times and a couple times they did pass [img]images/icons/grin.gif[/img] ) I removed each card one by one and tested them alone.Every one failed, except # 4
I guess I'm the first kid on the block to have this problem. wouldn't be the first time for that [img]images/icons/grin.gif[/img]
So I am sending them back to sweetwater/digi and am having 3 new/refurbished dsp cards sent to me for 350 ea. Not a bad deal.....only thing that sucks is my warantee expired two days ago! [img]images/icons/grin.gif[/img] Wouldnt be the first time thats happened either.
I have come to this conclusion,
1. when software and computers takes a dive, your screwed.
and
2. if they say it comes with a 1 year warantee, expect problems after one year.
Thanks,
-Ben
Old 08-05-2003, 08:35 PM
Lee Blaske Lee Blaske is offline
Hold on! I think it would be pretty extraordinary for three cards to go belly up at once, unless you also have a serious computer problem. Do you have another computer you could use to test these cards?
Also, I've never tried this, but I'm not sure you can test Mix Farm cards without them being hooked up properly to a core card, can you?
Lee Blaske
Old 08-05-2003, 10:46 PM
you know, I have been thinking the same thing. I am really worried that I will receive the new cards tomorrow, swap them out and the problem will still be there. If it is, I havent got a clue what to check next.
Could it be the 192's? This doesnt sound like a problem from that. It sounds internal if that makes sense.To me (and the digidesign rep) it seems like everything is leaning towards the cards since two of them work perfectly but as soon as I put in the third in, it crokes.
Also, It also runs out of voices very fast. Even when I increase the playback engine's dsp to 2, I still can't get enough voices. (even for just 20-25 mono tracks @ 44.1) Also, does using outputs use up dsp? I have 60 o/p but since I have removed the cards, I am only allowed 16 o/p. and if I attempt to use all 16 o/p it tells me I do not have enough dsp? even if I remove all my plugins. I still get the same message.
please, dont scare me, I have a big band tomorrow and it is very hard to cancel on 25 people [img]images/icons/grin.gif[/img]
either that...or I might have to go back to the adats for a day.......KILL ME.
Thanks,
-Ben
Old 08-05-2003, 10:50 PM
And yes, I do have another pro tools system (HD1) in my B room and for some god awful reason. I didnt think about doing that. My wife is sleeping. I could sneak out like a maniac. [img]images/icons/grin.gif[/img]
Thanks for the idea. I might try that in the A.M.
Thanks,
-Ben
Old 08-05-2003, 11:41 PM
Either I missed it or you didn't mention exactly what test these cards failed.
Since all TDM cards are attached via the TDM ribbon cable and pass clocking informatin via that cable a problem on one card can surface on another card(s).
Although it is possible for a card to go bad it is very unusual.
You mentioned testing the cards individually, not sure exactly what you mean by that but Digitest requires that you have atleast a core card and an interface connected and powered on to work. One of the tests is proper clocking which originates at the 192 and passes to the first card via the I/O cable and then to the other HD cards via the TDM ribbon cables. If any link in this clock chain is bad or broken, you can see problems on one or more cards and not necessarily a card that has a problem.
I would suggest re- testing, if you haven't already, with a single 192 I/O connected to your HD core card only (remove all other HD cards from the system). Disconnect any other 192's from each other and/or from any other HD card.
Test a single HD card (core card) with a single 192.
If it passes, then try adding an HD Process card and TDM ribbon cable. If this fails, swap out the ribbon cable and test again. If this fails, swap out the Process card.
So on and so on with the other HD cards...
Following this path should allow you to narrow the culprit down and hopefully save you some time and money.
Jon Connolly
Digidesign Product Specialist
Support FAQ
Old 08-06-2003, 12:38 AM
Default BAD CORE CARDS?
I have been having problems with a odd sound occuring randmomly while I am using pro tools. (usually while mixing with a client) It sounds like a clocking problem but after further invetstigation and troubleshooting I think it might be the cards. The sound has developed from a low pitch out of phase sound to complete distortion as if I was using a lo-fi plug in.This usually occurs on the o/p of my 3rd or 4th 192. Is it possible for the cards to corrupt?
Digi- Do you think it would be in my best interest to have a spare card around in case this happens again? These cards arent cheap and this doesnt seem like something to just have "lieing" around for an emergency.
Also, a little off the topic here, I am thinking of sending the cards in and buying three more with a expansion chass. How much will this run me and do you think this is in my best interest? I run a high volume recording studio and I cant have this happening when I have to mix big projects every day.
and how much will it cost me to fix the cards? I think they still might be in warrantee.
Littel confused and at a loss for time right now.
Thanks for any help.
Thanks,
-Ben
Old 08-06-2003, 12:42 AM
also, what is the digi preferred customer card about?
and how do I sign up?
Thanks,
-Ben
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 02:39 PM
prottols core cards mix core to hd pci to hd pcix to hd pce Filmusic Windows 1 03-24-2011 04:24 PM
Mac Pro Dual Quad core compatable with HD pci core & accell cards? PT8716 Pro Tools TDM Systems (Mac) 3 06-28-2010 07:35 AM
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! A Spooner Tips & Tricks 6 07-08-2009 06:55 PM
2 MIX Core cards... maxserg Pro Tools TDM Systems (Mac) 6 09-23-2004 06:13 PM
