Old 07-31-2003, 02:43 PM
Benjiman Benjiman is offline
Default Problem with Clock???
I am running a mac g4 933 on os 9.2 with pro tools hd3/5.3.1 vr 2 software and a sync i/o
For some odd reason, when I go into playback I get some very strange clocking sound. It actually sounds pitched way down and like its late from latency. This only happens when something is in record though. (another track)
I have trashed my preferences, changed the playback levels from 96 voices to 48 voices and so on. I have changes the hd buffer size from 1012 to 128. I cannot figure out what the problem is. I have had this setup with zero problems for over a year and now this happens and I havent got a clue where its coming from.
Is this a software issue? or a hardware issue? Has anyone else had this happen?
Thanks in advance!
Thanks,
-Ben
Old 07-31-2003, 02:48 PM
Default Re: Problem with Clock???
I am thinking of reinstalling dae.
Thanks,
-Ben
Old 07-31-2003, 03:56 PM
DigiTechSupt's Avatar
Hello,
Whats the clock source on the Sync I/O set to?
If you have the Sync I/O set to external sync, make sure the device is running at the same samplerate as the current session.
Does the problem persist when the Sync I/O is set to internal for its clock source?
Also, make sure all of your interfaces are chained together via loop sync with the Sync I/O as the loop master.
Mike
Avid Audio Tech Support
Support FAQ
Old 07-31-2003, 04:02 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
another thing I thought of...are you recording from a digital input or analong input?
Derek Jones
Sound Engineer / Producer / Composer
Derek Jones Linkedin
Megatrax Recording Studios
Megatrax Studios Yelp Page
A-list Music Artist Page
Old 07-31-2003, 08:16 PM
reinstalling dae has fixed the problem.
thanks for the replys though.
Thanks,
-Ben
Old 07-31-2003, 08:26 PM
but, my clock source is set to internal. I am not syncing anything up, it just sounds like a clocking problem....know what Im mean? Sample rates are all the same.
"Also, make sure all of your interfaces are chained together via loop sync with the Sync I/O as the loop master."
I know this is not the problem.
"another thing I thought of...are you recording from a digital input or analong input? "
Its an analogue input.
I reinstalled the pro tools 5.3.1 Vr. 2 software and the noise is gone. I am not sure what it was or where it came from.
BUT THE GHOST IS GONE!
[img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]
Thanks,
-Ben
Old 07-31-2003, 11:39 PM
Glad you got it figured out.
Mike
Support FAQ
Old 08-04-2003, 11:14 AM
sound keeps coming back. what is causing this?
Thanks,
-Ben
Old 08-05-2003, 02:07 AM
I think its one of my cards causing the problem. I noticed today mixing down a poject. I cannot get past my second farm card without having these exact problems.
Is it possible the cards can be damaged or corrupted? And will Digi replace this its been just under a year since I bought the system. If not does anyone know how much it would be to fix the card, expand to a expansion chassity and get two more cards?
also, how long do you think it will take digi to fix this?
Thanks in advance.
Thanks,
-Ben
Old 08-05-2003, 02:09 AM
I think these cards are a tad bit expensive to just have on lay away in case this happens. Does anyone else have cards in stock to replace them if they go bad in the middle of a session?
Thanks,
-Ben
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 5 02-26-2014 09:26 AM
Problem detected with audio clock. Check clock source and sample rate are correct mongrel8686 Third Party Interfaces 11 08-01-2013 08:42 PM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 08:22 PM
problem detected with audio clock. check that your clock source and sample rate are c angeleda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-05-2010 07:09 PM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
