Workspace Slowness!!!
Is workspace slow to you guys like me? I get the Rainbow of death everytime I click on anything in there. Makes me not want to use it at all. It doesn't quit or anything but, it is very very slow.
Thanx Marc
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies) YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc |
Re: Workspace Slowness!!!
Normally, workspace shouldn't be slow. I recently had a drastic sluggish response in workspace with the spinning beachballs, and traced it down to a connected drive that was having directory problems.
Run Apple Disk Utility's Verify Disk / First Aid on all of your drives to see if there are any problems, and fix as needed.
www.clifnorrell.com |
Double that quote and do a pref and database trash.
Thanx Guy's. I'm going to do that now. This is the first time I'm even using the Workspace thing as I want to try it out and see what all it can do as I've heard sooo much about it. It's just the last time I wanted to do this, it just seem like it was sooo slow before but, I didn't want that to stop me from trying this time. Is there anything I should know before getting into Workspace?
Thanx... I'll report and try to find a cure if this doesn't work. Marc
By the way, Do you guys have problems with Disk Utility and it taking a longtime to start doing it thing. Never had that problem running in 10.4.11. Ever since I upgraded to Leopard it has been slow as well....
Thanx Marc
Trashing the pref's did the trick. Wow, works much much better and sooooo much faster. WOW, 99.9 percent change.
Thanx Guys... That's why I come here... You guys are the best. Marc
At least to me, it sounds like you're on the right track, just might try the www.deshaies.com free application once and see if things work faster. Don't forget to empty the trash and reboot. YOu will loose your preferences if you've set any, but it's no big deal, VS. a crummy running system. Workspace should move Ok if you have a Mac Pro with 5 GB RAM.
Marc
JC |
I was out of commission for a couple of days. |
overall slowness | tonejunkee | Windows | 9 | 11-04-2011 06:59 AM |
New 27" LED Monitor Causes PT Slowness? | Siegfried Meier | Pro Tools TDM Systems (Mac) | 5 | 10-26-2010 04:16 AM |
Sudden Pro Tools LE slowness | efernan1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 10-08-2005 06:03 PM |
6.1 Graphic Slowness | Siegfried Meier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-12-2003 08:34 AM |
general slowness | AdamFrick | Pro Tools TDM Systems (Mac) | 12 | 11-23-1999 09:36 AM |
