Old 07-27-2003, 11:51 PM
Benjiman Benjiman is offline
Default Patch bay for Pro Control?
Is there a way to incorpoate a patch bay w/ a pro control?
In order to use analogue equipment, obviously.
Or are more people than I think, mixing solely in pro tools?
thanx
Thanks,
-Ben
Old 07-28-2003, 12:11 AM
jackruston jackruston is offline
Default Re: Patch bay for Pro Control?
Pro Control has a monitoring section which handles either surround or a stereo mix with alternative monitoring pair etc. It does not handle any audio involved in your actual mix. There would be no advantage to patching anything into the pro control path unless it was just for monitoring purposes. Equally pro control takes up an output pair for its monitor section so it wont save you any outputs other than the alternative monitors feed....so just patch up the interface if you need to.
Mixing with a Pro Control is mixing in the box. It merely uses an ethernet connection to exchange control messages with pro tools. Its just a control surface, not a mixing desk.
Old 07-28-2003, 01:23 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
like Jack says except that bringing everything on a patch can have advantages like switching between stereo mode and 5.1 setup or to have more stereo inputs available for patching to the sources. ours is on a patch ... very handy at times.
Chris Lambrechts
Applications Specialist- Live Sound
Old 07-28-2003, 02:23 AM
derF derF is offline
If you have a couple of 888s then of course you can!
Just run your sends out of un-used outputs and back in as aux inputs. I do this all the time with vintage bits of gear. I'd still class this as "mixing in the box".
I just have a regular bantam patchbay with my 888s and outboard on.
[img]images/icons/wink.gif[/img]
Old 07-28-2003, 10:03 AM
"pro Control has a monitoring section which handles either surround or a stereo mix with alternative monitoring pair etc. It does not handle any audio involved in your actual mix. There would be no advantage to patching anything into the pro control path unless it was just for monitoring purposes. Equally pro control takes up an output pair for its monitor section so it wont save you any outputs other than the alternative monitors feed....so just patch up the interface if you need to. "
patch the output of say my 480 to the i/p on a 192? Then it would be normalled? and you couldnt move it, right?
"Mixing with a Pro Control is mixing in the box. It merely uses an ethernet connection to exchange control messages with pro tools. Its just a control surface, not a mixing desk."
So your still mixing with the mouse basically? Can you control plugin parameters like the oxford eq from the controller?
Thanks btw.
"like Jack says except that bringing everything on a patch can have advantages like switching between stereo mode and 5.1 setup or to have more stereo inputs available for patching to the sources. ours is on a patch ... very handy at times."
how is your setup?
"If you have a couple of 888s then of course you can!"
"Just run your sends out of un-used outputs and back in as aux inputs.
and when you bounce to disk. It will record the auxes or whatever is being sent to? Thats nice!
"I do this all the time with vintage bits of gear. I'd still class this as "mixing in the box"."
Yes I would to and I to have a ton of older stuff that I use still.
"I just have a regular bantam patchbay with my 888s and outboard on."
Mine is attached at the console.
I have a Jade S Sountracs
Thanks dudes for helping me.
Thanks,
-Ben
How do I get the expression pedal to follow in patch canges (ground control pro) magie78 Eleven Rack 2 11-27-2011 10:38 AM
Control 24 with patch bay. melvinR ICON & C|24 5 02-25-2011 06:25 PM
Ground Control Pro - initialize CC switches with patch settings? drebin Eleven Rack 4 11-23-2010 02:56 PM
Ground Control patch names = 11R patch names? drebin Eleven Rack 5 11-23-2010 12:54 PM
Structure Assigning patch with the Triangles next to patch name? VanAmp Virtual Instruments 1 09-06-2008 09:45 PM
