Old 01-03-2011, 02:05 PM
nuancerec nuancerec is offline
Default Unable to save session copies w/ Root Settings Folder
I've been able to save session copies fine for years, but recently PT 8.03 is giving me the "Could not 14405" error message. It happens with every new session. I tried all the usual methods, importing tracks into a new session, starting fresh, toggling the check boxes.
Apparently the "root plug-in settings folder" is causing the problem, as when I uncheck that, if saves the PTF and doesn't display an error message.
Any ideas?
- Morgan
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Plugin "Set Root Settings Folder" PROBLEM dee dee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-09-2008 09:46 PM
Plug-In Settings root folder problem TJS Pro Tools TDM Systems (Win) 1 06-12-2008 04:03 AM
Cannot save plug-in settings to Root Settings folder SimonORorke Pro Tools M-Powered (Win) 1 01-18-2008 08:38 PM
Easiest way to switch root folder of PT session slangification Pro Tools TDM Systems (Mac) 7 09-09-2002 10:14 AM
