OSX 10.9.5 no waves in audiosuite??
Just noticed my waves plugins are not in the audio suite drop down menu??
Waves version installed os 9.3 anyone no how to fix this issue do i have to rescan a folder or something. Ive tried a fresh install but this didnt sort the issue. Thansk Raoul
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
This is strange as I’ve just checked my Mac Book Pro which is running 10.9.5 and waves are in the audio suite drop down menu?? I used same installer and everything??
I’m confused ?? Sent from my iPhone using Tapatalk
Raoul Crane
Re: OSX 10.9.5 no waves in audiosuite??
Sorted, some how I must have hit don’t use audio suite plugins when pro tools first scanned the folder. Waves support pointed me in the right direction
Raoul Crane
Well I thought it was sorted, booted Mac up today and the waves plugins were missing from the audio suite again. I closed PT held shift and reopened PT and guess what?? The box next to don’t use audio suite was ticked again. Now I no for a fact I didn’t tick it this time. I’ve sent waves support an email hopefully these can help me
Raoul Crane
That is something you usually do when installing? tried running the installer again? Chris
Hi Chris
Run the installer 2 times now, still the same ?? Sent from my iPhone using Tapatalk
Raoul Crane
Could try trash prefs User/Library/Prefs/Waves/pluginFolder_scanView Chris
Thanks Chris I’ll try that
Raoul Crane
That worked Chris, thank you
Raoul Crane
Using Waves Tune in Audiosuite | Mark Swanson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-28-2011 10:26 PM |
waves overwrite in audiosuite | utility | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-03-2009 10:24 AM |
Waves V6 can't use "Audiosuite" | modulo2008 | Pro Tools TDM Systems (Mac) | 2 | 07-09-2008 09:29 AM |
Waves AUDIOSUITE latency | Darin Donovan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-31-2003 09:11 PM |
Waves 3.0 / Audiosuite question | daiker | Pro Tools TDM Systems (Mac) | 11 | 01-17-2001 12:41 AM |
