Issue with Waves Central Updates
Last night I tried doing an update for my Waves plugins using Waves Central (latest version). I'd select the plugins to update, select update and everything would start, then about 1/2 way through I kept getting this message that it had stopped and to check my internet connection. But there was no interruption in my internet connection...its been solid and fast. This happened like 4 times before I gave up.
Has anyone else run into this using Waves central? This is the second time I've tried doing updates and this happens.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Re: Issue with Waves Central Updates
It’s most like an issue with Waves servers. Try again at some point. Or simply uninstall waves central and reinstall. Or sign out of your account and sign back in.
I figure its something on their end because I know my internet was just fine. I'll try again another time and see what happens.
I experienced a similar error a few versions back.
Try clearing the WC cache in settings if not already. If that doesn't work and things aren't normal at a later time, you might have to resort to the repair function in settings.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory |
Also remember too, that if you come to doing installs with samples that the progress bar can look like its frozen for quite a while.
In this situation I find it best to install the plugins only, then come back and do a SD sample install, then a HD sample install. Breaking it up this way helps to ensure that the plugins get installed and if you do have issues it kind of informs you about which part of the process is problematic. |
Pro Tools missing V9 plugins from Waves after updating Waves Central | williamg | AAX Plug-ins | 4 | 12-14-2019 05:54 AM |
New Waves Central software | musicman691 | AAX Plug-ins | 15 | 04-06-2017 02:10 PM |
Waves Central must update? | musicman691 | AAX Plug-ins | 4 | 04-12-2016 04:33 AM |
Anyone else unable to use Waves Central | crizdee | General Discussion | 3 | 01-25-2016 01:27 PM |
Waves Central | K.I. | AAX Plug-ins | 62 | 01-01-2016 07:52 PM |
