Repeatable Crash - searching workspace
http://protools.ideascale.com/a/dtd/239322-3779
Running PT12.5HD Open a session Open workspaces Search for a file in the upper right search bar. PT crashes I've tried it on different sessions and it's the same deal. Anyone else wanna try?
Re: Repeatable Crash - searching workspace
No problem... No bug, search works fine.
Win7 sp1 PTHD12.3.1
--->If you don't like what i wrote: Click: JuanPC Click: View Public Profile Click: User lists^ Click: Add to ignore list. Solved. |
You're seeing this on 12.5 only, correct?
Yes that's the only version I have installed
I have a Mac laptop, that I will try a little bit later.....ill have to install PT on it. I have a Windows laptop as well , but I will assume that this is not Windows related right now.... Thanks guys
just tested here on 10.11.4 partition with PT12.5 (non-HD) ... no issues here ..
Ok, I just finished downloading all the basics for my laptop
I am running 10.10.5 on the laptop as well....I will see how it goes
So I finally got it all downloaded and installed.
Laptop running 10.10.5 and just installed all Avid content, Air Plugs and Xpand2 along with PT12.5. Same deal is happening. I went searching for 2 files in the workspace....after creating a new session and bang..... Where do I send the crash logs to?
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 06-07-2016 at 12:26 AM. |
Well well well......got this message from a case I opened up....
----------- Hi Daniel, Thanks for making contact with Avid Customer Care. We are sorry for your inconvenience. I could reproduce the symptom on my MacBook Air. This issue should be the one logged as a known issue on our development database and under investigation. PT-214651 Pro Tools is crashing when performing an advanced search in the Workspace This is about the advanced search, but I could reproduce with the simple search. This issue should be fixed in the future update of Pro Tools. --------— So I assume that I don't have to do anything to follow up on that one, right? It seems to read like he either logged it, or knew about it....right?
Same with me as well. Don't recall it happening with any version prior to 12.5
Found this thread cuz I thought it would have been figured out already. Crash Logs are already sent in. Thanks. my first contribution I'm thinking my sig will appear with my specs nvm
Mac Pro 5,1 2x 3.46 Hex Core Xeon 96 Gb 1333DDR3 OS X 10.14.6 Samsung 970pro 2x 1TB NVME HighPoint 7101a / Open Core 0.7.0 EFI SATA Bay 1 Focusrite REDNET PCIe Pro Tools 2021.3.1 AMD Radeon RX Vega 64 BM Intensity Pro Last edited by Mertisrules; 06-08-2016 at 08:09 AM. Reason: No Sig |
There's another thread on here somewhere with this same issue. Also on Gearslutz. I'm having the same issue with 12.5 - iMac i7, El Capitan. One touch of the workspace browser and it crashes every time.
EDIT: This did not happen for me on previous PT versions. |
Repeatable Crash in 12.4HD | gonzolagonda | Pro Tools 12 | 1 | 01-25-2016 04:44 AM |
PT 10 repeatable crash | T-Low | Pro Tools 10 | 17 | 10-09-2014 12:06 PM |
Repeatable Crash (Just FYI) | themadarchitect | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-01-2011 01:34 PM |
Workspace crash when searching or auditioning | hesnodgrass1 | Pro Tools TDM Systems (Mac) | 7 | 03-18-2005 04:30 PM |
Repeatable crash | Submersible | Pro Tools TDM Systems (Mac) | 0 | 05-12-2003 02:51 PM |
