Tech Support AudioVision & PT24 Mix on one machine
Is it possible to run AudioVision and ProTools 24MixAV on one machine ? I´am thinking about the following configuration : PM 9600 with 7-Slot Magma Expansion Chassis. AVID Boards within PowerMac. Exchange of Atto AudioVison Controller against Atto DualChannel UW.Slot Order within the Chassis is
• Magma Exp Card • PT Mix Core with ADAT-Interface connected • PT III PCI with 888-Interface • DSP farm PCI with 888-Interface Can this work ? Regards ! Toko |
Re: Tech Support AudioVision & PT24 Mix on one machine
Toko
It is not possible to run a PT 5.0 AV Mix system, and AV Disk I/O in the same system. You need to seperate systems, one for AV and the other for PT Mix. You could use Pro Tools 5.0( using Disk I/O no A/V option ) and AV in the same system because they can use the Disk I/O. A/V cant use the Mix card. Mj Digidesign Tech Support |
New tech support tools - Tech Support Folder | DigiTechSupt | Technical Alerts | 0 | 08-07-2007 08:13 AM |
Audiovision and machine control | David Lamb | Post - Surround - Video | 2 | 11-21-2002 11:34 PM |
Tech Support-Nubus AudioVision | G2 | Post - Surround - Video | 0 | 06-23-2000 08:17 PM |
Tech Support : PTAV & AudioVision on one machine | Toko | Post - Surround - Video | 3 | 02-18-2000 08:17 PM |
AudioVision Tech Support in L.A. | Rick Sanchez | Post - Surround - Video | 1 | 11-03-1999 02:15 PM |
