  #21
Old 10-23-2022, 05:50 PM
audiolex1 audiolex1 is offline
Default Re: Waves V14 - Has anyone actually installed on Mojave?
RX 580 8 GB here. Things run fine. Going to update to V14 tomorrow and test out 2022.9
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
  #22
Old 07-19-2023, 07:20 AM
hoovoo hoovoo is offline
I know I'm late here, but today I tried installing Waves 14 on Mojave and Waves Central gives me a warning that version 14 is not compatible with my system (10.14.6). It gives me no other option. How did you install it? Is there a workaround? a trick? ThankQ
  #23
Old 07-19-2023, 03:10 PM
Bob L's Avatar
Bob L Bob L is offline
Well it's been over a year since I did it, but IIRC I just dismissed the warning and it installed.
Bob
Without a song
The day would never end
  #24
Old 08-14-2023, 03:06 AM
Actually, you'll need V13 for official Mojave support. That OS was released quite a while ago now, almost 5 years in fact.
https://www.waves.com/support/tech-s...ins|version-13
While you might be able to do a workaround to get V14 installed its not officially supported. So there's a very good chance that you may not get much in the way of help from Waves should something go wrong. Of course there's also the risk of running into instability issues as well, or just overall buggy behaviour.
Just something to be aware of.
  #25
Old 08-14-2023, 06:45 PM
filmixer filmixer is offline
I wouldn't do it. Install V13. Your V14 license will work. If there's a new plugin you want, like BB Tubes or something, just install the V14 for ones you need.
Mark Ettel C.A.S.
  #26
Old 08-31-2023, 10:45 PM
Or you consider upgrading to a bigger bundle that has all your older plugins plus extra. I’d recommend holding off for sale pricing if you were going to consider that though.
  #27
Old 09-04-2023, 02:45 AM
Farhoof's Avatar
Farhoof Farhoof is offline
You can still install v14 on Mojave if you use the offline installer and the Waves Central that comes with it. But be sure to disconnect from the internet when opening Waves Central or it will update itself to a later version and prevent installing instead of just giving you a warning.
I'm not sure about the versions though, you might need the Waves Central from the v13 offline installer and manually install selecting the v14 offline package. It's a hassle, but it works.
  #28
Old 09-30-2023, 04:45 AM
While you can find workarounds to install it tat approach really isn't advisable.
Since it's not designed to run on the system you could experience anything from buggy behaviour to complete system crashes and loss of work. It may not happen but it is a definite risk. Because it isn't officially supported the only help you are most likely to get from Waves is to either upgrade the OS or uninstall it and put V13 on your system.
Which is pretty much what everyone is telling you to do here.
HTML code is On
[SOLVED] Has anyone successfully installed Waves v9 on 3.1.1? Jeffery Foster VENUE Live Sound Systems 5 06-25-2015 01:53 AM
Waves 9 installer only installed AAX? anackman AAX Plug-ins 1 05-10-2014 07:01 AM
Having Waves 5 and 7 installed together Reb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2009 05:14 PM
Installed Waves plug-ins but there not in the Audiosuite ?! Fusty_FM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-05-2002 05:22 PM
waves ver 2.8 installed but not showing up paxrec Pro Tools TDM Systems (Win) 0 07-04-2001 09:51 AM
