AVID, How can you STILL NOT HAVE FIXED "Edit/Mix Window Follows Bank Selection"???
Where's that guy at that told us it would be fixed in PT11? Somebody hit him.
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix | Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone |
Re: AVID, How can you STILL NOT HAVE FIXED "Edit/Mix Window Follows Bank Selection"??
On which control surface?
Artist Mix and Control. The only way it works is if I hold down 'ctrl' on the keyboard while selecting a track on the surface. This has been broken for forever. Why won't you guys fix it??
Auto bank to selected was fixed with v2.7.1. Have you tried that Eucon version with Pro Tools v10.3.x? If you are using Pro Tools v11, did you install Eucon v3.0?
If Edit/Mix Window Follows Bank Selection is enabled, on the control surface if you select a track that track should scroll into view on the screen, in the respective Edit or Mix window. This does not work. To make it work one has to hold 'control'. I can't remember how I figured out the holding 'control' when selecting trick but that does it. I'm runnin' Eucon 3 on PT11. Still no god damn fix...
this needs to be fixed
the 002 was better at this simple one button touch
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram |
So, since they didn't fix it...
What's new in Eucon 3.0?!?!?!?!
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
Nothing... I guess it was a compatibly release as the previous version wasn't working with PT11.
wow!! #fail
They say something in the installer about it being reprogrammed from scratch for performance improvements.
Can't see any differences however (certainly not in Eucontrol), and you still cant even copy paste softkeys-function/macro around. |
edit/mix window follows bank selection Eucon/PT9? | engininja | Artist Series | 47 | 11-23-2014 09:42 PM |
Edit Window Follows Bank Selection. Edit Window Follows Bank Selection. Edit Window.. | Focuret | Artist Series | 17 | 01-18-2014 03:53 AM |
Whoever gets PT11 first, please post if "Edit Window Follows Bank Selection" is fixed | Focuret | macOS | 0 | 04-07-2013 06:08 PM |
Avid seriously, when will the Edit Window Follows Bank Selection function be fixed?! | Focuret | Pro Tools 10 | 1 | 11-23-2012 02:04 PM |
PT 8.0.1 Edit Window Selection Bug (FIXED!!!) | tha]-[acksaw | Pro Tools M-Powered (Win) | 15 | 09-28-2009 08:48 AM |
