ReVibe 2 go to reverbs?
Does anyone have a favorite reverb preset that they always use? Things like Room Large etc always seem to sound a bit metallic or cavernous.
How do folks approach just giving a vocal - adr perhaps - a bit of space? What about making adr sound outdoors. Does anyone have a preferred outdoor setting? A small slap back delay helps to make it sound like you're in an alleyway or built up area. Does anyone have a particular favourite preset for this as there are a few? Interested to know if people even use ReVibe or whether you mainly go straight to Altiverb! |
Re: ReVibe 2 go to reverbs?
I have a lot of verbs, my favorite's are exponential audio, but Revibe IMO is a great reverb as well, I still use it a lot. There are many great verbs these days, everyone has a opinion , as with wine there are many to chose from
Intel Intel Core i7-5930K 3.5 GHz Processor ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram Thunderbolt EX 2 Windows 10 Pro ................................ 2013 MacBook Pro Retina i7 Quad-core, 16gb ram. Mac OSX 10.11.6 ........... Mac Pro (Late 2013) 2.7 GHz 12-Core Intel Xeon E5 Memory 128 GB 1866 MHZ DDR3 Graphics AMD FirePro D700 6144 MB PT Ultimate 2022.4.0 on Mac PT Ultimate 2020.12 on Windows Logic Pro X 10.6 Nuendo 12.0 ........... 1_Antelope Audio_Orion Synergy Core Studio |
Revibe to my ears is a tad fizzy. Much prefer Exponential Audio too. Both are great with automation though.
Try the low pass filter, more pre delay and less verb overall and you will get better results with Revibe.
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Thanks guys will experiment again. It sounds fizzy to me as well but will try the file, pre delay and room size (which is what I'm guessing you mean by reverb, or perhaps you mean decay time)?
My adr tends to sound fake when I stick reverb on it. So it's definitely something I'm doing wrong. Even small room reverb is a bit rubbish. Medium sounds like a large Hall. I'm just hoping to find a setting I can save as I preset for a standard home room as that's where most of my adr ends up being. Thanks :) |
Most reverbs are designed so their presets sound good on music emulating stone or wood sounding reflections. Most interiors used for dialogue have people and furnishings, carpets and beds all of which scatter and absorb high frequencies. As suggested above, on ADR you need to Eq the reverb quite drastically, particularly if you are trying to match ADR around boom mic recordings. Revibe is fine for a lot of things. I like Altiverb for person speaking in the next room and some of its outside and really small spaces. It tends not to need as much eq but if the spaces available don't match it's not so tweakable.
Rob Walker AMPS
www.robwalkersound.com |
The absolute best way I've found to match ADR is to persuade the recordist to record simple hand claps in every room where the is dialogue.
Then use exactly the same mic to record the ADR as was used on set at an appropriate distance. Use Altiverbs import impulse function to make a mono reverb from the hand clap. Put mono reverb only on the centre. Result. Seamless. It has to be thought about before the shoot though, its not always possible.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
This works in theory (you can actually use the clap of the slate for this), but I've never found the results convincing.
AAX Reverbs | AiWTech | Pro Tools 10 | 19 | 05-02-2012 12:59 AM |
Plugin Reverbs vs Outboard Reverbs | midnightsun | Pro Tools TDM Systems (Mac) | 52 | 09-07-2009 02:46 PM |
what your fav reverbs?????? | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 01-08-2007 11:36 AM |
Revibe vs TL Space reverbs | francis eyre | Pro Tools TDM Systems (Mac) | 11 | 03-18-2006 07:38 PM |
