Old 05-02-2007, 09:56 AM
stillroasting stillroasting is offline
Default importing reduces sound quality?
hey folks...i have a stereo aiff 16/441 that came back from the mastering engineer, but the fadeout is a little off and i need to fix it myself, so in order to impact the sound quality as little as possible, i created a 16/441 aiff session, imported the aiff file (all it has to do is split L+R), made the new fadeout, consolidated the region, and exported L+R back to stereo 16/441 aiff...but now the track sounds muddy, like its a lower resolution. which one of the things i did made the track muddy? i can't figure it out...
thanks
SR
Old 05-02-2007, 10:47 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: importing reduces sound quality?
A direct copy of a digital file won't affect the sound quality. Is it the part you added that sounds muddy or the entire track?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 05-02-2007, 12:01 PM
Windshore Windshore is offline
Did you render the new file by "Bounce to Disk"?
There has been discussion on the forum before about the difference in sound quality by "bounce to disk" verses recording to an outside medium. There's a lot of speculation as to why, but what you're hearing may well be valid.
If you have another editor / program you can use, like Logic or a dedicated mastering program, you may have better luck.
Old 05-02-2007, 11:03 PM
i didn't use bounce to disk, i used the export function, shift apple K...
as for the other reply, its the whole track that sounds muddy now
this really makes me wonder about the fidelity of digital...i A-B the two versions and theres a pretty significant difference.
the only thing i can think of is that the original unedited master aiff came from a PC system and i'm using a mac....
Old 05-03-2007, 10:48 AM
There is no difference in a file that comes from a Mac or a PC. If it is an AIFF file, it is identical.
A digital copy will not change the sound.
Describe how you took the file into the computer. Also, compare the input track and your edited track, not the exported track. If you input the file again with no editing, how does it sound? Does it change on input or after editing or after exporting?
Park
better quality power cable = better quality sound? dbvoyager General Discussion 22 04-15-2012 06:08 PM
Sound Quality Lost After Importing Files MrWillsi3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-30-2009 03:32 PM
Importing MP3, quality issue? DanDan Pro Tools TDM Systems (Mac) 1 11-17-2008 12:53 PM
Lose quality by bouncing & then importing audio? brandin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-20-2005 10:11 PM
Best Method for Importing Lower Quality? spicyitaliano Pro Tools TDM Systems (Mac) 4 01-12-2005 03:39 PM
