Hi! I´m trying to put a HD 2 system together and everything works perfect working with stereo mixing put when creating a 5.1 session the surround-panning is hey-wire!
Left speaker is correct, sound panned to centre speaker comes out of Right front, panning to LS sound comes out of RS. On top of that one of the speakers were DOA so when panning to Right speaker nothing comes out...and that is setup to the RS output. This is probobly just a laughable thing but this is the first time I´ve put together a HD-system so I´m not sure what to do. We´ve got a 192 i/o that sends the signal analog to a SPL Surround Monitor Controller. I´ve checked the connections 4 times - they are correct and I don´t know what more to do. As I mentioned above, stereo mixes work correct with panning Left and Right. Writing this makes me feel that the SPL is the faulty piece here... Please help! iMartin
PT9 HD3 Mac Pro 2.88 quad, 32 GB Control24 Apogee Duet 2 Macbook pro i5 2.5GHZ, 10GB |
None? Not even with an idea?
Hmmm...did you verify in the I/O Setup that things are routed properly? I *think* the default config for stereo is simply L->Out 1, and then R->Out 2; but for 5.1, the default is L, C, R, Ls, Rs, Sub...no? Unless you specified DTS/Pro Control monitoring during PT install, in which case it would be L, R, Ls, Rs, C, Sub. The former would then have your right channel mis-outputted, and could potentially result in a bit of fun...
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
I cheched those things as well...I think I´ve narrowed it down to be a faulty snakecable between SPL and speakers...
well after many test and hairs pulled out we finally manage to find a guy to help us out. seems that there was a was a conflict between 192 i/o and SPL. Protools was sending out signal standard 5.1 (L C R LS RS LFE) but SPL was working in SMPTE...oh well it´s all sorted out now!
Sound only coming out of left speaker | chrisshack89 | Windows | 5 | 05-29-2013 12:35 AM |
Just setup pro tools 10 and have no sound coming through the ouput | mingalls | Pro Tools 10 | 2 | 08-13-2012 09:50 AM |
5 speaker sound installation setup | tomjoyce | Post - Surround - Video | 8 | 03-05-2011 11:56 AM |
Sound only coming from left speaker on my MBox mini | ajdevera | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2010 09:20 AM |
All of my bounces are coming out wrong... | TheLP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-21-2004 12:11 AM |
