Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 12-10-2019, 02:54 PM
Space_Monkey Space_Monkey is offline
Default AAE-9173 Error - "Ran our of CPU Power" - but all plugins are disabled
Hi Everyone
Well, here I am, struggling to find the time and energy to learn how to use PT to sketch a song (which is difficult in and of itself), and now my little friend, error AAR-9173, stands in the way.
This is the "Ran Out of CPU power" error, which suggests that I disable all the native plugins (what's a "native" plugin anyway?).
Thing is, they are all disabled, and the CPU is barely working, except that it's still at 100%. There's something that bothers it, but I don't know what. See screenshot attached.
Can anyone please advise? Help me get the creative juices flowing!
Thank you in advance!
System:
Intel i-7 6700K, @ 4.00 GHz, 16GB RAM
Win 10, 64-bit,
PT 2019.6.0
NVidia G-Force GTX-750
Old 12-10-2019, 02:55 PM
Default Re: AAE-9173 Error - "Ran our of CPU Power" - but all plugins are disabled
You know what? I had the Waves thingy re-scan all the plugins just now, before I saw the error. Could that have had anything to do with it?
Old 12-10-2019, 03:16 PM
What exactly do you mean by "disable" have you actually moved the .aaxplugin files out of the plugin folder, trashed prefs and started Pro Tools?
What other standard troushooting have you tried? Checked all third party plugins are up to date? Just trashed prefs (should always be first step), tried starting with another empty session, etc. See troubleshooting under "Help us help You" at the top of every DUC web page.
What sample rate, and IO buffer size are you running at? Post a SiSoft Sandra report if you try more troubleshooting and are still stuck.
We cannot guess what you mean when you throw unclear comments out.. describe exactly what you are doing and seeing what exactly where. e.g. what CPU meter are you looking at. If windows is showing lots of CPU use and you have not removed all the third party plugin then you likely have a bad plugin... a common cause of CPU problems.
A native plugin is a plugin that uses the computer CPU for processing, vs. a DSP plugin that uses an HDX DSP card processor, or in the past HD card DSP processing. None of which you have.
Power PC but get error "Pro Tools ran out of CPU power." jakebake Windows 2 11-19-2019 09:42 PM
MC Mix connects correctly first time, "Network Error" after power cycle. A Chapman Artist Series 4 07-18-2011 04:04 PM
Help! Error 9128 "Your'e running out of CPU power. Take out some plugins to free..." LATablette 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-26-2003 07:48 PM
do i have to buy "european" version of digi002, or use "american" with power adaptor? stoka General Discussion 3 10-04-2002 06:28 AM
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled OKden Pro Tools TDM Systems (Mac) 2 10-27-2001 04:24 AM
