Old 07-13-2013, 02:23 PM
P,B,S P,B,S is offline
Default HD 11 launched and worked in 32bit mode. How is that possible.
Ever since I noticed that I havnt used HD11 once.
seems like another avid white lie to me.
Old 07-13-2013, 02:54 PM
Drew Mazurek's Avatar
Default Re: HD 11 launched and worked in 32bit mode. How is that possible.
I assuming the same way a 64 bit plugin can operate in a 32 bit environment. Just a guess.
www.drewmazurek.com
Old 07-13-2013, 02:55 PM
WKG WKG is offline
And how have you confirmed this to be true?
I7-4930K, X79-Deluxe, 2133 32 GB,
GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2,
Win 10 Pro, PT Ultimate 2019.6 REAPER 6.02
RME, Daking, Heritage, ISA, Sytek
ASUS N71Jq i7 940xm 8GB DDR3
PTHD 12.1 REAPER - Win 10 HP
Old 07-14-2013, 05:39 PM
edwinh edwinh is offline
I was wondering this, too. I fired up PT 11 on a Mac Pro 1,1 running OS X.7.5 and it worked great. I haven't had a chance to play with it extensively and find out what the limitations are, but I expected it to be a non-starter due to lack of 64 operation on that computer.
2.5 Ghz i7 MBP
16 GB RAM
OS X.11.6
PT 12.6
MH ULN-8 x3
Old 07-14-2013, 06:31 PM
How do you know it's working in 32 bit mode? Any Mac running OSX 10.8.3 or later only runs in 64 bit mode. Then again you haven't said if you're on a Mac or pc - those things matter in the answer you know, right?
Are you sure you're not confusing 32 bit recording in session setup with the bit depth of the operating system? You do have a history of getting things mixed up.
Jack
QAPLA!
Old 07-14-2013, 06:41 PM
P,B,S, might be confused by I'm not. It's working in a 32 bit environment where it's not supposed to be. A Mac 1,1 can run Mountain Lion, but you have to jump through significant hoops, which I'm not doing. Unless you know of a way in which 10.7.5 and a 1,1 can run 64 bit apps which Apple and the rest of the world don't know about, it does work in 32 bit mode as applications supposedly don't run in 64 bit mode in this scenario.
2.5 Ghz i7 MBP
16 GB RAM
OS X.11.6
PT 12.6
MH ULN-8 x3
Old 07-14-2013, 09:24 PM
drumdandrum drumdandrum is offline
A Mac Pro 1,1 running 10.7.5 will absolutely run 64bit applications. Open up "Activity Monitor" and you'll see a list of programs that have (Intel 64 bit) in the "Kind" column. Pro Tools 11 is not "supported" on this computer and OS but that doesn't mean it won't run.
BTW I can't find a "Open in 32-bit mode" option on the Pro Tools 11 App.
Old 07-14-2013, 09:39 PM
OK, I guess I am pretty ignorant about this. What limitations does the 32 bit EFI impose on PT 11? Or are the limitations applicable to Mountain Lion which is not as necessary as Avid might imply?
Thanks so much for your information!
Edwin
2.5 Ghz i7 MBP
16 GB RAM
OS X.11.6
PT 12.6
MH ULN-8 x3
Old 07-14-2013, 09:53 PM
Edwin
My understanding is that Mountain Lion simply won't install on a 32bit EFI without jumping through hoops. I'm not sure if this is an artificial limitation imposed by Mac OS programmers or if there is a legit reason for it. I'm also not sure if/how Pro Tools will be limited or will perform on a 10.7.5 OS, I just know that it isn't supported by Avid. It might run perfectly!
Old 07-14-2013, 09:55 PM
I just know that if it isn't supported by Avid, it might run perfectly!
Amen!
<quote modified>
2.5 Ghz i7 MBP
16 GB RAM
OS X.11.6
PT 12.6
MH ULN-8 x3
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 11:30 AM
Reason 4 doesn't like being launched by PT 8 groovebrother Pro Tools TDM Systems (Mac) 19 03-17-2010 04:29 PM
Getting Pro Tools 8 to work in Windows 7 32bit - Digi002 (what worked for me) DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-11-2010 03:39 PM
ProTools could not be launched... Alex Rodriguez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-28-2005 09:53 AM
Pro Tools" could not be launched Klara 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-16-2005 10:29 AM
