Old 09-19-2010, 09:29 AM
hendrixrocker2 hendrixrocker2 is offline
Default How To Install Pro Tools 8 on Windows 7 32bit
Hello,
I've been doing some research but haven't found anything for this. I am looking for help installing my pro tools 8 onto windows 7 32 bit. I've heard to not connect your Mbox 2 mini while it is installing and some other things. Can anyone either give me a quick step list or a tutorial link. Thanks
Old 09-19-2010, 10:10 AM
MikeLip MikeLip is offline
Default Re: How To Install Pro Tools 8 on Windows 7 32bit
I believe you only need to do the turn on/off dance for the 8.04 driver which is here: http://duc.digidesign.com/showthread.php?t=277427
For <8.04 just download; run windows in minimum config; and hit setup. I believe you should target 8.01 or 8.03 at this time. (cs2 in both cases from memory).
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells
Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized.
Google the DUC
Search Avid
Old 09-19-2010, 07:54 PM
What worked for me with Win 7 x64:
Uninstall any previous version, with interface disconnected(Mbox) or powered off(002/003). Now, install PT8 with the hardware NOT connected. When the installer asks for the interface, DO NOT connect. Instead, click OK and the install will finish. Reboot and run the 8.0.4 updater. DO connect the interface when the updater asks for it. Finish the install>reboot>open PT>type in authorization code if required.
Computer reboots at Pro Tools LE 8.0 startup (Windows 7 32bit) jobo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-04-2011 02:40 AM
Pro Tools 9 and Windows 7 32bit sunking3 Windows 2 08-14-2011 05:42 PM
Someone please help! Mbox 2 pro install for Win 7 32bit orangeproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-19-2010 11:37 PM
Getting Pro Tools 8 to work in Windows 7 32bit - Digi002 (what worked for me) DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-11-2010 03:39 PM
Installing Pro Tools 8 on Windows 7 32bit Promblem illbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 11-02-2009 01:27 AM
