  #121
Old 07-29-2014, 09:50 AM
Raoul23 Raoul23 is offline
Default Re: Waves Studiorack
Originally Posted by JFreak View Post
But who's buying?
So so true
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
  #122
Old 07-29-2014, 09:57 AM
Drew Mazurek's Avatar
Originally Posted by Raoul23 View Post
So so true
Somebody must be!! Where else did Waves get the money to fund the development of this system?!?!
www.drewmazurek.com
  #123
Old 07-29-2014, 10:06 AM
YYR123's Avatar
YYR123 YYR123 is offline
Wup
Daniel
  #124
Mike496's Avatar
Mike496 Mike496 is offline
Yep, bought TDM and WUP for Protools, got studiorack and digigrid.
  #125
Old 07-29-2014, 10:08 AM
YYR123's Avatar
Originally Posted by Waves Audio View Post
In our tests we got 54 non-optimized SSL Channel mono instances on an HDX card at 48 kHz, and 18 instances at 96 kHz. We felt that this was unfair when compared with any SoundGrid server or DiGiGrid IOS or DLS interface.
Please note that the SSL Channel uses full 64-bit arithmetic, which is easily processed natively on Intel engines. HDX uses TI DSPs, which are 32-bit engines with some limited extensions for 64-bit arithmetic. However, doing proper double-precision on these chips costs more than 2x CPU.
If you think HDX is bad you should try the DSP chip on my UAD-2 card......ludicrous
#crackerjackdsp
#intelhasmorepower
Daniel
  #126
Old 07-29-2014, 10:13 AM
JFreak's Avatar
JFreak JFreak is offline
Same here. In other words: bought into Digidesign/Avid DSP platform with a promise of continued support, but did not get what was promised.
Janne
  #127
Old 07-29-2014, 10:32 AM
Emcha_audio's Avatar
Originally Posted by studioj11 View Post
I believe Waves Audio was referring to an HD "Accel" card.
Yes those numbers for hdx are actually quite good in my opinion also! And the fact that we are limited to 64 stereo voices with digigrid driver or avail I/O when connecting via HDX makes the large amount of dsp avail on the digigrid server slightly less exciting. I think we would hit the limits stated about the hdx card just by digigrid voice count before hitting a dsp wall anyway.
Of course these are theoretical benchmarks and are just given to show avail dsp ... other plugins will require different amounts of resources.
Regardless I am curious about this product and will be keeping an eye on reviews and reactions, as well as third party interest / support.
64 mono channels actually (or as they themselves call it voices)
Sure, we're glad to have the opportunity to discuss it with all of you.
In our tests we got 54 non-optimized SSL Channel mono instances on an HDX card at 48 kHz, and 18 instances at 96 kHz. We felt that this was unfair when compared with any SoundGrid server or DiGiGrid IOS or DLS interface. Therefore, we took an HD Accel card and filled it with SSL TDM versions, and multiplied that by the most optimistic optimization prediction from Avid, which according to their numbers is up to five times more powerful. This gave us the benchmark standards that we published.
Alright so no optimization was done, and since you haven't mentioned it, it's safe to assume that you fed the whole 3 blocks to the chip since you didn't uncoupled the 3 blocks (GUI / CORE / PROCESSOR) from each others.. and then you wonder why you had such bad results.. but wait, then you did something even worst, you went ahead and used HD accel which does not have 8 x 32 bit path of processing per clock beat per chips but 1 (so 8 times less processing per chip right away) that had a slower clock time than the hdx by a factor of almost 3 (and more since the HDX can do 8 process at the same time vs 1 for the HD accel) and had 2 x less chips on 1 card, and then decided to just multiply this by 5? You do know that some plugins have went up by almost 10 to 15x more right on HDX compared to their TDM versions?
So basically thanks for confirming what had been told to us prior to this but by a wave aficionado and not someone directly from wave. You didn't do a proper job at porting the plugin and even more you went with a totally UN-scientific (to be polite) benchmark.... Way to go!
I was hoping that your company would have made it's true diligence and really took the time to actually do a proper test and not some duckedtapedpatch job ala red green show
https://www.youtube.com/watch?v=qZDCBVy22W8
Sheesh please don't take this a slant to you personally, but somewhere someone in your company made a truly bad move with that kind of work.
Manny.
  #128
Old 07-29-2014, 10:38 AM
studioj11 studioj11 is offline
Originally Posted by Emcha_audio View Post
64 mono paths actually
I'm pretty sure when used natively (as in with the soundgrid driver) digigrid provides 128 mono paths of networked audio, or 64 stereo. At least that is what I have read.
When used via the digilink avid connectors I think you are limited to available io as the server is treated as an io insert. Which btw would make offline bouncing inoperable yeah?
  #129
Old 07-29-2014, 10:39 AM
JFreak's Avatar
If the box has two DigiLink ports, it is 64 mono channels.
Janne
  #130
Old 07-29-2014, 10:56 AM
Exactly for the offline bounces, you need to convert all the plugins you have in your session that would be on the digigrid as native. I linked you the SR pdf (hopefully at the right place) where you can see the amount of total voices, and they do mention ( don't remember if it's there) that they consider 1 mono channel as 1 voice.
Here's an other excerpt
Hardware Connection | Number of I/O Channels
DLS/DLI Avid expansion DigiLink connector | 16 mono
DLS/DL Directly to Avid PCI/e, single port | 32 mono
DLS/DLI Directly to Avid PCI/e, two ports | 64 mono
SoundGrid supports a maximum of 64 mono StudioRacks.
Manny.
HTML code is On
Waves license not found after Waves update Talisker Pro Tools 10 5 03-26-2014 10:14 AM
Keep Loosing all Waves presets from Waves tool bar!! crizdee Pro Tools TDM Systems (Mac) 4 03-12-2010 03:59 PM
Not enough space on Waves only ilok to download Waves update 7 crizdee Pro Tools TDM Systems (Mac) 38 11-09-2009 06:19 PM
Plugs Advice: Sony vs Waves - Sonalksis vs Waves? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2005 02:31 PM
WAVES Protools7 update and Waves tech support x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-11-2005 07:24 PM
