Old 03-17-2015, 10:01 AM
Pythagor Pythagor is offline
Default Machine Control installer
Hi
Anybody can help in finding Machine Control installer for 8.0.1 HD?
Any help is greatly appreciated.
Thanks
Old 03-17-2015, 05:12 PM
Chief Technician's Avatar
Post Re: Machine Control installer
Pro Tools HD 8 Options Installers
Old 03-18-2015, 12:26 AM
Default Re: Machine Control installer
Great! Thank you!
Old 03-18-2015, 01:39 PM
another question just aroused.am i correct that to connect PT 10HD and 8HD via machine control i need 2 x sync io and keyspan adapter?
thanks!
Old 03-18-2015, 01:48 PM
Question Re: Machine Control installer
I am not certain I fully understand your question. Is your objective to lock two separate Pro Tools system together with MachineControl (9-pin)?
Old 03-18-2015, 02:24 PM
hi
yes exactly as you said)
Old 03-18-2015, 07:11 PM
Each system needs a SYNC peripheral (I/O or HD). Each system needs a Keyspan adapter. Each system needs MachineControl. I think you need the black cable that came in the box for the MachineControl. The MachineControl box includes a cable for deck control (gray) and one for remote mode (black). I have never used MachineControl this way.
Old 03-22-2015, 11:21 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
You ca use a standard 9 pin cable from Sync IO to Sync IO.
If you are using Keyspans, then a 9 pin din to 9 pin din between the 2 adapters.
The Keyspan was a workaround as many Sync IOs had 9 pin issues.
You really don't need Sync IOs, if you just want to lock via LTC over serial.
IMDB
HTML code is On
Machine Control, no 9 pin Deck Control Section uisdean.macleod Pro Tools 10 1 06-25-2014 06:53 PM
Machine Control BIG installer bug, wont start rbhun Windows 10 02-11-2011 07:26 PM
where's the Machine Control Installer? EarHole Post - Surround - Video 4 10-14-2010 04:10 AM
MIDI Machine Control out of control zenbarai Post - Surround - Video 3 04-19-2002 07:08 AM
Machine Control's supported machine J. S. Bach General Discussion 0 01-17-2000 07:06 AM
