Old 11-03-2011, 05:53 AM
SHRED SHRED is offline
Default Pro Tools's recorded audio is delayed. Wave file written late on the grid. Unreliable
I had this problem for a while now and just can't work it out.
I am wondering if anyone else had this problem and worked out how to fix it.
Basically, Pro Tools HD2 v8.1.1 is recording things late. (OSX 10.6.6)
Means, even played perfectly in time, the recorded wavefile is written late (roughly 30millisec), so I have to nudge it all the time. It is totally weird.
It seems to only do it when recording with a lot of tracks playing at the sametime in a song (96+ tracks).
If I go to the end of a session, record with just a click, there is no delay!
Anyone have any ideas? Really appreciate your help.
Old 11-03-2011, 12:18 PM
Craig F Craig F is offline
Default Re: Pro Tools's recorded audio is delayed. Wave file written late on the grid. Unreli
and your ADC settings are?
Thank you,
Craig
Old 11-03-2011, 12:41 PM
No Delay Compensation on.
Old 07-24-2012, 05:08 PM
Doug Hamblin Doug Hamblin is offline
Im having the same problem! Would love to know if, and how, you got it resolved, thanks....
Old 07-24-2012, 05:56 PM
I never found the solution. Tried everything I can think of.
I don't have such problem with my LE systems on other machines...
Old 07-24-2012, 06:06 PM
CME CME is offline
Default
Any plugs on your master fader? Or the aux feeding the headphone mix? I know that messes with things on a native system. And you say delay compensation is off. Have you turned it on just for kicks? Just some thoughts.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 07-24-2012, 06:11 PM
I had some plugins then on the Master Fader, I already finished that project but the problem is still on going with other things. It just happends randomly and it is not consistent.
I upgraded to pro tools 9.06 and I still have the problem.
Old 07-25-2012, 10:34 AM
studiojimi's Avatar
studiojimi studiojimi is offline
limiter on the 2 bus will yield 30 - 40 ms latency
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 07-25-2012, 10:47 AM
WernerF WernerF is offline
The recommended method is to record with Delay Comp on and make sure that you have the Compensate For Input Delays box checked in the IO setup in the input and output section. I overdub on big sessions all of the time with this method and have never had your problem. If anything, people rush most of the time. Ha
Old 07-25-2012, 11:54 PM
elicious elicious is offline
and if they're not Russian,
they're Dragon!
(who members that???)
e
ihatetyping
Audio Recorded from MIDI track ahead of the beat/grid CalebB macOS 1 10-22-2012 11:03 PM
Overdubs being recorded LATE? Doug Hamblin macOS 1 07-24-2012 12:03 PM
wave plugins still being written for tdm? Emcha_audio Pro Tools 10 8 10-23-2011 05:49 AM
Recorded audio is late. Any ideas on how to fix this? stingerns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-29-2009 02:33 PM
Recorded Audio late by 3000 samples (MBOX) melat3mg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-08-2004 09:01 AM
