digi 003 analog oputs?
read the manual it says nothing as for how can they be used, i would like to route some individual tracks out of one of these analog outs so i can use an external processor, and looped back into the new track in the digi?
Re: digi 003 analog oputs?
Look up Hardware Insert in the reference manual
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
thanks flommer, but my only manual is the small thin book my digi came with. will keep trying
click my signature.
You should be able to get to it with ProTools open by going to the help menu.. There are also a bunch of .pdf instructions that get installed here: <system drive>/Applications/Digidesign/Documentation/ProTools There are actually many different pdfs in the "documentation" folder
i think digi should put all you guys on the payroll(lol), the coolness and help people get here is truly priceless
thanks so much for the file, but it's way to confusing, i'll try to find a tutorial on youtube, peace buds
Hey Basslik its pretty simple; just go out from the 003 using output 3(for starters; any one will do except 1-2) but out of 3>into whatever unit u have of use; Now the unit 'of use', come out of it into the 003 input '3'; inPT, instead of choosing the Multi/ or Mono Insert, u go down to the i/o & choose from there; U may need to set that up in ur i/o options too; Keep in mind, u may/will run into a latency issue... & u have to make sure that ur NOT using that input/output on any other track...
this should get u started BUT still look into the other info provided as well by the other fellas...
[quote=...Keep in mind, u may/will run into a latency issue......[/quote]
Yo Key, since you brought it up and I consider you a "king of massive LE mixocity" Do you use or have you ever (wow I sound like a cop) the Mellowmuse ATA? I've been meaning to try the dem but I'm in the middle of some pieces and don't wanna upset the applecart. And on my new tune I'm using Reaper...what a fine little app. Wilson (not the Volleyball) |
Really, 1 can argue that MellowMuse is just as good as the ADC in HD, because that isn't the most flawless of ADC's either... Nicse
Digi 192 Analog Interface | finale | Buy & Sell | 0 | 06-28-2012 06:46 PM |
Analog Inputs 5-8 on Digi 002 | Jenkins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 01-12-2005 09:39 PM |
Can I get more than 8 analog inputs into Digi 001? | foo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 11-22-2002 12:54 AM |
Dumping 1in. Analog to Digi 001 | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-18-2002 09:30 AM |
fostex analog out into digi | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-11-2001 08:47 AM |
