Midi Bug In 12.8
Hi all,
Has anyone else had midi data corrupted or read differently when "up" grading to 12.8. Where I have trimmed a midi clip 12.8 is now playing all the notes prior to the trim, which leaves two lines of midi on top of each other in the same clip (see picture). These notes can't be deleted without consolidating with the previous clip and then manually deleting. This has destroyed/disrupted many hours worth of editing. In other clips pro tools is playing muted notes and clips. Does avid even test releases before upgrading? It feels like they are tone deaf to how users actually use the product. |
Re: Midi Bug In 12.8
Maybe you should look at the latest version and the two previous release note? Just a thought. Here is fixes for 12.8.2, but I don't have time to read through it for you. http://avid.force.com/pkb/articles/r...-Release-Notes
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Thanks for the tip
Unfortunately it is happening in 12.8.2 |
I had this problem today.
I had a session I needed to do an edit on, and I tried to "drag out" the "beginning" a MIDI region via the Trim tool, to get a few extra beats from the original performance that had been edited down. But when I tried to drag out the edge (over the adjacent original part, which I had made into a separate region and muted), I got an Assertion error (I didn't note which one, because I had a deadline to deal with). This was a pre-12.8.2 session that I was opening in 12.8.2 I just checked it again and was able to drag the region edge this time. It seems random. I did delete the prefs this morning, but I had the Assertion Error afterwards. Maybe I needed to do a full CPU restart. MacOS 10.12.6 Mac Pro 5.1 loaded custom. Pro Tools HD 12.8.2 HD I/O Last edited by massivekerry; 10-27-2017 at 10:48 PM. |
12.8.2 PT HD native. OSX Sierra Exactly as you described. |
Thanks for the confirmation.
This one is probably the final straw for me... trialling Cubase and Studio One - looking to not use Pro Tools for new sessions going forward. It's disingenuous for Avid to be touting all these 'midi improvements' when they can't even get the basics (latency, clips etc.) right. |
Have had this bug too in a biiiiig way. Probably the worst Pro Tools issue I've ever encountered and has been pretty devastating.
I have however managed to find a solution that's been working for me after a lot of trial and error: Create a new PT session at a different sample rate (source sessions presenting the problem are all at 96K - this procedure with new 96K sessions didn't work for me, but did with 44.1K sessions). Import Session Data of affected MIDI tracks from original session without importing tempo information. Assuming these playback correctly (with the exception of tempo obviously), consolidate the MIDI regions on each track. In the original PT session, bring these consolidated tracks back via Import Session Data. Delete/deactivate the original tracks. For me, this has worked to 'disinfect' the MIDI data. It's been fine with the very extensive automation that was already in place and got me back to where I was. This needs to be fixed ASAP though. Utterly unacceptable that a product release boasting MIDI improvements has this bug. We have an album due for delivery this month and more than 50 PT sessions full of meticulously programmed MIDI data that have suddenly turned to ****. I've also found the issue affects all session files within a folder - from the latest to those haven't been opened for over a year. Edit for reference: OSX 10.11.6, 2014 Mac Pro (trash can), Avid Omni IO/HD Native, Pro Tools HD 12.8.2. Issue seemed to come with the 12.8.2 update for me. Also presented with same sessions on a 2017 Macbook Pro. Last edited by brenjwc; 11-13-2017 at 07:20 AM. |
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
I have a strange problem where I input MIDI notes from my keys (any of them, I have three) and nothing plays faster than quarter notes. Some notes are on top of each other. Notes group in clumps and play in quarter note rhythm. Interestingly, I can go to other projects or create a new file, and MIDI inputs fine. It appears this file is corrupt of some configuration has changed. I have compared settings on this file to other files and cannot see any difference. Anyone else have this problem. This thread is the only thing online that comes anywhere close to my problem.
BUT ... do you have INPUT Quantise tunred on maybe ??? set o Quarter NOte ???
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
003 midi ports not there in midi studio setup? Unable to record midi now? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2009 12:06 AM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
USB midi vs. din midi-(the old style midi connector) | Ling | Pro Tools M-Powered (Win) | 1 | 02-19-2009 02:15 PM |
