Mute / Solo "Shift +" shortcuts don't work
OSX 10.6.8 & PT 9.0.3
In both Edit/Mix windows, I select a track and press SHIFT + M or S, yet nothing happens. I cannot solo/mute via shortcut at all. Just tried SHIFT + R & I can't Record-arm either. There is no mute/solo automation as I tried a fresh non-templated session. Nada. Fails to work whether in Latch or X-OR solo mode. It's like PT suddenly hates the shift key. I am very sure there is some embarrassingly-simple setting or toggle I'm missing here -- but I cannot for the life of me figure out how to make this shortcut work again Any ideas?
iMac i7 & MBP Retina i7 OSX.9.2 /Pro Tools 11.1.2 (w/ special guest-star appearances by Logic 10.0.6) / RME FF800 + Dangerous D-Box "I survived the Great Launch Predicaments of PT11 2013." |
Re: Mute / Solo "Shift +" shortcuts don't work
You have to have the Edit cursor on the track(s) for the Shift + R/I/S/M to work.
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
For some reason I thought I should be able to select a track in the mix window & do Shift + R/I/S/M --- I just remembered I only can do that if I click the "link edit and track selection" option in the editor window --- now the edit window moves the Edit cursor to each track that I select over in the Mix window. For some reason I had this de-selected awhile back and must have got used to that behavior and thought it was default. :P Thx again!
"Tuner" and internal "DSP" doesn't work on Mbox 3 Pro | luckydjacks | FireWire & USB Audio Interfaces (Win) | 129 | 06-20-2014 03:25 AM |
Pro Tools 11 quit/crash when typing "Shift" | Fir3bird | Pro Tools 11 | 24 | 07-07-2013 07:48 PM |
Toggle Track view ("Opt"+"-") doesn't work | LukeFromBerlin | macOS | 3 | 04-01-2012 04:43 AM |
BUG: "Shift-S" for solo causes PTLE8/CPTK crash | reichman | Post - Surround - Video | 19 | 09-11-2009 07:40 AM |
Keyboard shortcuts for solo and mute? | Richard901 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-02-2006 02:02 AM |
