Can someone outline the best way to get audio, video and an EDL out of Avid Expres Pro into Protools for dubbing?
Is an OMF, presumably embedded the correct way or what about AAF? I have a Canpus ADC 100 box so would need a DV video. What about taking the finished dub back into Avid? OMF or AAF expert from Protools or simply a time stamped stereo file? I have an HD 2 Accel system with PT v6.7 on a G4/933 with Canopus DV box. Thanks, Mike. |
OK,
I don't really know anything about AAF but exports from Avid Xpress to ProTools is something I do know about. I take it that you've got the DV Toolkit? In my experience, the best way to go is to export an embedded AIFF OMF (choose option OMFI 2 Embedded - this consolidates your media and timeline info down into one file - make sure that you give yourself some good 'handles') This is what I have found to be the most reliable in the past. You can try a non embedded OMF, they have worked for me the the past but not consistantly. When getting your final mix back into Avid you can either bounce the stereo mix down into one handy AIFF file with sync plops to indicate start time and import it into your Avid or play it out onto tape (again with sync plops) and then digitise it back into your Avid - have to say that I've never used the time stamping between platforms, so don't know if that would work or not. You can re-export your tracks from the ProTools to go back into your Avid if you really need to. Picture wise - is it a ProTools AV option rig or do you use Quicktime videos with the Canopus? Email me and I'll be happy to talk about it - I'm based near Manchester too. |
Mike, if you've not already looked - the thread about OMF Imports started by MarkPresti - has all the info you need. I already described the process from an Avid Adrenaline to PT on this thread - and i assume its pretty standard for most avids, they do try to maintain the workflow across systems.
and i'm in manchester too....in fact i'm about 20' from soundbird right this minute!!
adam taylor video editor/dubbing editor/sound design/motion graphics/compositor United Kingdom |
Well folks,
I got the files today from the client whose editor obviously knows his stuff as I got an embedded OMF and a .dv movie and it all opened up in Protools (I do have Digi-Translator) first time with no problems. Thanks again to the Manchester crew for your help and advice. |
ProTools 11.1.2 Avid Tech: Video Problem Blackmagic Express | Nathan W. | Pro Tools 11 | 0 | 03-06-2014 11:40 AM |
Surrendering of ProTools Express failed need Avid help | Jokerman | Pro Tools Express on Mac OS X | 4 | 12-01-2013 04:17 AM |
59.94 Avid Project to ProTools and back | Rick Sanchez | Post - Surround - Video | 3 | 03-11-2009 06:43 AM |
protools and avid express | feakerboo | Pro Tools TDM Systems (Mac) | 1 | 05-08-2006 11:00 AM |
Bad Chunck Error -- Protools ->Avid Express | Kono | Post - Surround - Video | 1 | 08-07-2002 06:42 PM |
