9129 - Audio Processing is conflicting with other CPU tasks - Error help needed!
Hello, thanks for taking the time. My question is a two-parter.
Several years ago I purchased an MBox2 with ProTools LE 6.8.1. I have not used it too much in the past year or more but I have a new project to work on so am trying to troubleshoot some problems. Everything more or less runs fine except that I keep getting the now infamous "Audio Processing is conflicting with other CPU tasks... Try reducing HW Buffer size". After reducing buffer size, I get a similar error telling me to increase my buffer size, and the cycle repeats. After doing a search of the site I have read that I should start my own thread with my specific system details, as each system is different. So thats why I am here now, any help is greatly appreciated! From Sandra Lite: SiSoftware Sandra Computer Model : System Manufacturer System Name Workgroup : THE_PAD Host Name : KEVSCPU User : Kevin's Processor Model : Intel(R) Pentium(R) 4 CPU 2.40GHz Speed : 2.4GHz Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Integrated Data Cache : 8kB, Synchronous, Write-Thru, 4-way, 64 byte line size, 2 lines per sector L2 On-board Cache : 512kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector Computer Mainboard : Asus P4PE BIOS : Award Software, Inc. ASUS P4PE ACPI BIOS Revision 1002 10/28/2002 Bus(es) : X-Bus AGP PCI IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 1GB DDR Chipset Model : ASUS 82845PE Brookdale Host-Hub Interface Bridge (B0) Front Side Bus Speed : 4x 134MHz (536MHz) Total Memory : 1GB DDR Memory Bus Speed : 2x 223MHz (446MHz) Memory Module(s) Memory Module : Infineon (Siemens) HYS64D64329GU-6 512MB DDR PC2700U DDR-166 (2.5-3-3-7 2-10-0-0) Memory Module : Infineon (Siemens) HYS64D64329GU-6 512MB DDR PC2700U DDR-166 (2.5-3-3-7 2-10-0-0) Video System Video Adapter : RADEON 9500 PRO / 9700 - Secondary (PS2.0, VS2.0 276MHz, 128MB 270MHz, AGP 2.00) Storage Devices Maxtor 6Y080L0 (82GB, ATA133, 3.5", 7200rpm, 2MB Cache) : 76GB (C:) WDC WD400EB-00CPF0 40GB (ATA100, 2MB Cache) : 37GB (F:) MDT MD1200JB-00DUA3 120GB (USB/ATA100, 8MB Cache) : 112GB (J:) HL-DT-ST RW/DVD GCC-4320B (ATA33, DVD-R, CD-RW, 2MB Cache) : 524MB (D:) Logical Storage Devices KevsCDrive (C:) : 76GB (NTFS) @ Maxtor 6Y080L0 (82GB, ATA133, 3.5", 7200rpm, 2MB Cache) Ebay Drive (F:) : 37GB (NTFS) @ WDC WD400EB-00CPF0 40GB (ATA100, 2MB Cache) Audio CD (D:) : 0bytes (CDFS) @ HL-DT-ST RW/DVD GCC-4320B (ATA33, DVD-R, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A AUDIODRIVE (J:) : 112GB (FAT32) @ MDT MD1200JB-00DUA3 120GB (USB/ATA100, 8MB Cache) Peripherals LPC Hub Controller 1 : Intel 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge LPC Legacy Controller 1 : ITE IT8708F Audio Device : ASUS SoundMAX Integrated Digital Audio Audio Device : Creative Labs CT0090 Audigy Player Audio Codec : 61680 00F0h Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : ASUS P4B533 USB Controller 1 : ASUS P4B533 USB Controller 2 : ASUS P4B533 USB Controller 3 : ASUS P4B533 USB Controller 4 : ASUS P4B533 USB Controller 5 : Uli (Acer) ALI M5237 OpenHCI USB Controller USB Controller 6 : Uli (Acer) ALI M5237 OpenHCI USB Controller USB Controller 7 : Uli (Acer) ALI M5237 OpenHCI USB Controller USB Controller 8 : Uli (Acer) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : Creative Labs Audigy 2 Firewire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP LaserJet 1100 (MS) (600x600, Parallel) Scanners and Cameras Camcorder : Microsoft Microsoft LifeCam VX-1000 (Camcorder, USB) Network Services Network Adapter : Hamachi Network Interface (Ethernet, 100Mbps) Network Adapter : Macronix MX98715-Based Ethernet Adapter (Generic) (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. -------------------------------------------- Not sure if that's too much or too little information. Any help would be really really appreciated, this has been driving me up the walls lately. I was about to upgrade my RAM before reading that it may not solve the problem. Thanks again for any advice! |
Re: 9129 - Audio Processing is conflicting with other CPU tasks - Error help needed!
I got this error on my I7 when I had installed software from the cd provided by the motherboard manufacturer. So I'm guessing you have some other program running, possibly in the background, that's interfering with PT. Start with running msconfig and disabling all non-essential programs running at startup - disable ALL of them if you can, except for the Digi programs of course, and see if your problem goes away. If so, you can try enabling them one at a time until you figure out which one is causing the conflict. Also, make sure you try all the optimizations in the troubleshooting thread.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
The error is definately being caused by background services you are running. I had the same problem when i installed a wireless network card. Once I disabled the wireless network the problem disappeared. I tried to just disconnect but the problem remained. I had to disable the network and the re enable it ebery time I want to use the net.
Good luck |
PTLE 7.1 - Audio processing is conflicting with other CPU tasks. (-9129) | woodman01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-03-2008 10:58 AM |
audio processing conflicting with other CPU tasks | elvidge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-01-2006 11:03 PM |
Audio Processing is Conflicting w/ Other CPU Tasks | chillax69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-18-2006 07:30 AM |
Audio Processing Conflicting with Other CPU Tasks? | Mr Fiddle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-12-2005 11:54 PM |
Audio Processing conflicting with CPU Tasks | Sebastian C. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 11-02-2004 10:52 AM |
