HELP: ProTools Needs At Least 1GB
Sorry guys I've seen this posted a couple times but all the answers have been toward XP (SP3) but I am getting the same issue running Windows 7 (32bit).
I have 1GB RAM and 2.20GHz processor. Any suggestions?? Thanks in advance |
Re: HELP: ProTools Needs At Least 1GB
Hello, right click on Computer and go to properties. Check the amount of ram there. 1 GB is the minimum, so if something like the graphics card is using only a few MBs it would be enough to put you below spec. If you decide to upgrade your ram to say 2gb make sure you get matching ram chips. 2 1GB chips. You will have better performance than mismatched ram.
changing from protools 8 audio only to protools 8 with video support | djkaz | macOS | 5 | 09-04-2013 04:00 PM |
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? | jgbsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2011 01:08 AM |
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! | G ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-12-2011 07:09 PM |
Sending protools projects to other protools users online | kdtufan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 07:18 PM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
