how do I copy midi regions based on beats
hi all,
does anyone know how I can copy say 16 bars of midi and duplicate over and over. This is the only thing stopping me from using protools for midi. Every time I record midi, it somehow splits all the notes into separate midi regions, and I am not able to just copy and paste what I just did. Can someone help me out. thanks |
Re: how do I copy midi regions based on beats
Make sure you're in grid mode. Select the 16 bars you want to repeat and hit "Alt-R". A dialog will pop up where you can enter the number of times you would like to repeat. Type the desired number and hit OK.
If the 16 bars you want are a distinct section of a song like a verse or a chorus, you might set the track display to "regions". Select the 16 bars you want and "separate region" from the Edit menu. Then you can select the region and copy or repeat it as in the above paragraph. Hope this is what you're looking for. Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
MIDI clips/regions copy/loops | madmarkdj | Pro Tools 11 | 5 | 09-08-2021 10:33 PM |
Can´t copy MIDI regions properly... | Firechild | Pro Tools TDM Systems (Mac) | 2 | 11-25-2012 04:27 AM |
How to copy and drag regions? | pukeuv | Tips & Tricks | 15 | 08-01-2008 03:52 PM |
? MIDI - copy a block/edit the copy changes the original too | blast9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2008 08:16 AM |
Lock Audio Regions to Bars/beats!!!! | meshtheflesh | Tips & Tricks | 5 | 02-15-2001 05:22 PM |
