Can't change sample rate of Digi 002 rack in PT11
Hey guys
I know the digi 002 is not "officially supported", but it does work with protools 11 . However, I cannot change the sample rate, which is a bummer because I can't open any of my sessions because they were recorded at 96. Can anyone out there help me with this issue. It seems silly to me thanks
Intel i7 3770k 24 Gigs of Ram Windows 7 Professional Digi 002 rack Protools 10 |
Re: Can't change sample rate of Digi 002 rack in PT11
Use core audio - or aiso and resave them or what ever
Try disabling the 002r as your default sound device in Windows.
Same thing happens with buffer settings if Windows is trying to use the 002r for sound.
Chaz Shifting Sands Audio www.shiftingsandsaudio.com soundcloud.com/shiftingsands Asus X79 Deluxe | i7 4930K @ 4.1 | 32Gb Ripjaws CL9 GBLZ | Radeon R5 230 | Win7 Pro (64) | 256Gb Samsung 850 SSD | 2x 1Tb Seagate SATA | 250Gb Samsung EVO SSD | 128 Samsung SSD | Antec 650W | ProTools 11.3.2HD, 10.3.9HD, 12.5 | Cubase 9.0.20 Pro | Nuendo 8 | Studio One 3.2 Pro | RME UFX | 2x Octopre Mkii Dynamic | Alphatrack | DTouch | Logitech G510 | Kensington Trackball | Yamaha UX256
On a MAc, go to "System Preferences" and look at the bottom of the frame in the "Other" section. You'll see the 002 control panel. You can set the sampling rate there.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Thanks everyone for your help!!
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
PT 8.0.4 DIGI 003 - Can't change sample rate ! | coboune | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-06-2010 01:57 AM |
Digi 002 Rack Cutting Out - Sample Rate/Clipping? | GBradley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-24-2005 07:52 PM |
