Old 01-29-2010, 11:32 PM
GtrDude GtrDude is offline
Default 8.0.4b Optical ADat Clock Source
Before installing the beta driver I always had a check in ADAT" under
Hardware Setup>Optical Format.
Then under "Clock Source" I had it set to "Optical".
Now the word "Optical" isn't there any more.
Should I use ADAT or Ext WCLK instead?
I'm using Lynx Aurora both as a converter as the master clock.
Thanks
GD
Old 01-30-2010, 08:13 AM
Default Re: 8.0.4b Optical ADat Clock Source
Choose ADAT. You 'll know if its not working as you will hear clicks and pops if you try to record from the Lynx unit.
Can't select Optical Clock Source in Hardware Setup brassandzin macOS 1 05-11-2012 11:43 AM
The optical clock source is invalid when using pre sonus digimax 96, why? dekits 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-26-2010 08:39 AM
STUPID MISTAKE!! Optical Clock Source set wrong . . . AM I DOOMED?? The Zone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-13-2010 05:43 PM
Clock Issue on 192 i/o Optical [ADAT] Not Optical [Encl] Willard Pro Tools TDM Systems (Mac) 1 10-10-2007 01:23 PM
Clock Source: Word or Optical ADAT? RobMacki Pro Tools TDM Systems (Mac) 7 04-15-2006 06:32 AM
