#21
Re: Pro Tools has become a nightmare (Windows)
Keyscape has always been a bear on several Windows systems for me(but I sure do love the sound of it). My solution for that one is to use MiniGrand until the part is all tweaked. Then switch to KeyScape and commit the track
#22
#23
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#24
There are no VST in Pro Tools so thats an impossible development issue!
#25
Could be file corruption in the OS causing issues.
Go to command prompt, run as System Admin Run System File Check sfc /scannow This will identify and correct any system file corruption. After that is complete run the Pro Tools installer .msi in repair mode See if that helps with your issues. Mark |
#26
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
#27
Apologies meant VIs but you can use bridge software to make VSTs work
#28
Very true but I get you meant VI as VST Wrappers and VST plugins might cause issues Avid has nothing to do with on both platformsz
#29
Some interfaces Pro Tools will run, though very badly when the interface is still set in Windows as the the default playback devices. I have seen this fix quite a problem systems.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#30
I don't want to fuel the mac/pc wars, but oddly enough I just built a PC to give windows a shot after years of repeated crashes on my last 3 mac machines (2009 Mac Pro, a 2013 Mac Pro, and then a 2019 8 core macbook pro). I figured if it fails, the kids get a killer gaming rig. It's been two months now, and I'm probably jinxing myself by saying this, but it has been the most stable rig I've ever had! I can't remember a workday without multiple crashes/freezes/cpu errors on my macs. On this PC I've had one crash while attempting to change the io setup when opening an old session, but otherwise it's been so good! I'm sure some update will screw it all up for me one day, but I can't imagine it being any worse than it was with my last few macs on a daily basis, and at least I'm getting things done without interruption for the moment. Also, if it does start crashing as frequently, at least it reboots and launches sessions a little bit quicker.
Only two downsides so far. #1: No imessage! I'm having to use the ipad on my new s1 for messaging with clients/friends/family. Luckily the meters aren't really that important to me on there, and it seems like that's all the ipad does on the S1. And.... I'll probably just switch to a non apple phone for texting from the PC, but that's a whole different issue. It's not an easy transition when everyone in this business uses an iphone, and imessage holds your phone number hostage. #2: Learning new key commands hasn't been fun. I've been using Pro tools on macs since the late 90's, and I'm definitely fumbling around some to find the right key combinations occasionally. Last edited by thebeatless; 01-27-2020 at 10:44 PM. |
nightmare error in Pro Tools LE | Ryan Butler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 06-11-2008 07:02 PM |
Pro Tools 7.3 Upgrade Nightmare | PasteEater | Pro Tools TDM Systems (Mac) | 6 | 03-08-2007 04:51 PM |
Windows Service Pack 2 NIGHTMARE | mezzmeric | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 09-03-2004 11:22 AM |
HELP!!!! PRO TOOLS NIGHTMARE! (DIGIMAX) | dwdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-13-2002 12:18 AM |
Windows ME nightmare | Joe Cool | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-02-2002 05:41 PM |
