Old 09-23-2017, 12:46 PM
willl3 willl3 is offline
Default Re: right click select whole clip when trying to cut it
Originally Posted by joachim View Post
Could you clarify : do you then click at this position or are you going right away for a right-click ?
If you go on the position and click and then right-click, it should work.
If you go on the position and click , but move the cursor away from the vicinity of the position and then right-click, it cannot work.
The blinking cursor is at the position I want to cut in grid-slip-shuffle any mode doesnt matter
I put the cursor is the middle of a clip
its blinking nicely where I want to cut
as soon as I right click it selects the whole clip what is this? something with 12.8?
ALL I WANT TO DO IS RIGHT CLICK WITHOUT IT SELECTING THE WHOLE CLIP
I have to go to edit pull down select cut clip at selection (or control e)
I deleted prefs
fixed other issue I have on this board but this is an f'n nightmare
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram
Old 09-23-2017, 01:18 PM
I deleted prefs
I asked this question before and you didn't answer it - do you have the track name highlighted? Are you using the smart tool? If so, don't. Just use the I-beam tool.
Jack
QAPLA!
Old 09-23-2017, 05:13 PM
track is highlighted
smart tool on or off doesn't matter
blinky line on clip (middle, 3/4, 1/8) any where in the clip
I right click
the whole clip gets selected
What did AVID change this?
(I've been using protools since ver 6)
so this is driving me crazy.
looking under preference edit I cant find it any where
WHY WHY WHY!!!!!!!!!1
Old 09-25-2017, 01:46 PM
Dear Moderator,
Please move this into Protools software(win)as this seem to be a defect in this version of protools for win10
this is not a tip or a trick but a possible issue
also how do I delete my signature below there is no edit button
Old 09-25-2017, 01:51 PM
Dear Moderator,
You change your signature in your profile page.
Jack
QAPLA!
  #16
Old 09-26-2017, 03:31 PM
Current Response:
Entered on: 9/26/2017 11:45 AM Entered by: Osamu Kawabe
Hi Will, Thanks for making contact with Avid Customer Care. We are sorry for inconvenience. Our development team is aware of the issue: PT-233024 Right-click > Separate option does not work (new to PT 12.6) It is planned to be fixed in the next update of Pro Tools. Please use " Command + E " short cut as a workaround till the issue is fixed. Thanks, Osamu AVID
problem is that this protools 12.8 and still not fixed
when is the next update?
  #17
Old 09-26-2017, 06:09 PM
Current Response:
problem is that this protools 12.8.1 and still not fixed
  #18
Old 10-04-2017, 04:58 PM
It does not allow me to change the signature there is no edit pencil
  #19
Old 10-04-2017, 05:18 PM
You don't use an edit pencil - no such thing. Got to your user CP (control panel)and select the 'edit signature' tab on the left side of the page. In the right side which is about 80% of the page is a section titled 'edit signature'. Just click your mouse in there to place the cursor where you want to add/delete/change things and type away. You can preview your signature before saving it. It's that simple.
Jack
QAPLA!
Keyboard Shortcut to Select the Next Clip in Clip List TomMxEdit Pro Tools 12 1 02-27-2017 11:52 AM
select next clip in timeline (on all tracks) johannes1 Pro Tools 10 3 07-07-2015 09:48 AM
How do I select multiple regions in the clip list? Moviesound Post - Surround - Video 5 08-25-2012 05:31 AM
How select a clip with Artist Control? John Fishback Artist Series 4 05-21-2012 09:23 AM
grabber doesn´t select clip with fades Frank Kruse Post - Surround - Video 0 07-14-2005 08:44 AM
