Which interface/preamp would you recommend?
Hey all. I am looking for opinions on an audio interface and pre amp to pair up with PT9 and my iMac. I used to do some "basement" recording on my Digi 001 and my G4 Mac back in the day just to give you a sense of the level I have worked with. I always felt my system before was never up to snuff and want to make sure I leave some room for growth.
I have been waiting almost about a year with hearing of the release of PT9 and was considering going with the console version of the Digi 003 if they were going to release it with PT9, but have since decided against it with talks of them discontinuing the 003. I have a 2 channel Focusrite pre amp from back in the day which is decent enough for 2 channels, but need to look at the possibility of having to mic a drum kit in the future. I like most don't have as much money as I would like to spend, but also don't want to cheap out and regret it later. Most of the recording I will be doing will probably be on the level of advanced amateur to semi professional, so planning for expansion later may be important. I have been doing some looking already, but want to hear some opinions before I really set myself down a path. Any information may be helpful as in a way I would almost consider myself as starting over from scratch. Thanks in advance! |
Re: Which interface/preamp would you recommend?
If you need a control surface, the 003 is still a good value(and can be a bargain). If you don't need that function, The M-Audio Profire 2626 and Focusrite Saffire 56 are both worth a look. 8 mic preamps should take care of the average drum kit. The Saffire has 2 Liquid Pre's, which emulate several popular preamps(like Neve, API, Avalon, etc) which makes it worth the extra cash in my book I have and like my 003, but am still considering a move the the Saffire(or HD/Native if I can find the money).
Haha, I'm actually reading your post about the Liquid Saffire 56 right now. I was mostly looking at the 003 for the package of control surface, pre amps and PT software. Now that I know they aren't going to release it with PT9, it has me looking elsewhere.
For the price it seemed like a viable option at the time, but with the Digi pre amps and outdated software it makes me consider looking at other possibilities. |
Now I'm just trying to find out if I would have any problems using the LS 56 and the 003 together since they both are audio interfaces as well.
You will need to choose one as your interface. You SHOULD be able to run the LS56 software and route the 8 preamps to the lightpipe output. Once that is done, then the 003 can be the interface, with the LS56 connected via lightpipe to the 003 lightpipe input. In this setup, Pro Tools will see the 003 as the audio engine and the LS56 inputs will appear on the 8 lightpipe channels in the Pro Tools IO setup grid(as happens with any lightpipe interface connected to the 002 or 003 units).
Thanks again Albee. A few steps closer to getting things figured out.
Now I have to look into some other things like some new headphones and a few mics to fit into my new expanding budget. Hoping I can get my system coming together soon as I have been keeping my iMac packed away for use of recording only. Things would be so much easier if money grew on trees! |
So tempting, but the deal breaker for me is as I understand it, you would have to power down reboot, plug in the LS56 Firwire to change the pre choice on the liquid pres? Man I have gear fever, but if I understand it right, that is just a PITA. with that much time in between, trying to pick out what liquid pre you think sounds best, your reference from the last setting would be lost, I guess you could print a short take of each and decide. But that is a real buzz kill....
Brent Willoughby Kinetic Recording Studios Orlando FL. USA www.kineticrecordingstudios.com |
Once I usually find a good sound for my preamp though, I tend to stick with it until I feel that I don't like the settings. I have my Focusrite Twintrak Pro as well so in the end it gives me the choice of the liquid pres, the other 6 Focusrite pres or my 2 pres on my Twintrak Pro. It may be more then enough options to have certain channels dedicated to certain situation/setups.
27" iMac 2.93 GHz Quad-Core Intel Core i7 Mac OS X 10.6.7 4GB 1333 MHz DDR3 Focusrite TwinTrak Pro ProjectMix I/O PT 9.0.3 OWC Mercury Elite Pro 1.5GB/64MB Cache Signature under Renovation, just like my studio! ________________________________________ |
I see your point, and in a lot of cases you go with your go to setup. I almost would be good with that. But it sure would be nice to mic a kick drum lets say, you have your mic set up, man just to scroll through the liquid pre's one after the other, sure would be nice. I really am just starting to use the 003 for more then moving faders and pans, It is really is on another level then anything even close to the price. It can do some advanced editing if you dig into it.
I just had a thought, it's way late and I am sure I will find a flaw if someone else does not point it out first. I have a quad q6600 that has not been turned on since my P67 I7-2600k build. I wonder if there is any way to use two CPUs and route out light pipe into the 003 and use the liquid pres in real time. I am sure someone would of already thought of this, but guess this will keep me up while I fight myself to sleep... Quote:
Please recommend an Audio Interface for me | finalcut | Windows | 10 | 02-14-2012 02:47 PM |
Which interface and pre amp would you recommend? | Judicious | macOS | 19 | 06-02-2011 11:07 PM |
Mbox 1 - Recommend New Audio Interface | gerarddaly | Pro Tools 9 | 2 | 05-30-2011 09:56 PM |
Which interface do you recommend for scratch/demo tracks? | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-16-2008 09:00 AM |
Recommend 2-ch preamp/compressor? | MichaelK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-05-2001 11:03 AM |
