Standard MIDI File - What about Patch & Port?
Hello,
When importing a standard MIDI file into ProTools 5.0, is there anyway to ensure that the program change (patch) info and the MIDI output port info gets imported into the session as well? Of is it normal to have to set all of these everytime a standard MIDI file is imported into ProTools. Thanks in advance. |
Re: Standard MIDI File - What about Patch & Port?
Although I don't think the MIDI spec has been expanded to include Port information (like for a multi-port interface), each track should retain its channel info (1-16).
Program (Patch) changes are included in the MIDI spec and supported by Pro Tools. If your MIDI file contains them, they will be imported and played. (Change the MIDI Track's view to "Program" to see/edit them.) ------------------ Jeff Cohen Digidesign Tech Support
• linkedin •
Exporting standard MIDI file with tempo info | clint bennett | MIDI | 1 | 07-15-2005 11:32 PM |
Midi Patch file for Yamaha S08??? | TommyEllison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-01-2004 05:42 AM |
Midi Patch file for Yamaha S08??? | TommyEllison | MIDI | 0 | 06-30-2004 09:07 PM |
Midi with Roland XP-50 and Patch name file | Stevy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-20-2000 07:35 AM |
Oh to open a standard Midi file! | Nik | Tips & Tricks | 5 | 08-16-2000 10:56 PM |
