Reflected Impedance & Highest Output Level, 192?
Dear Tech Support,
Can you tell me what the Reflected Input Impedance is for 192 Audio Interface? I'm also looking for the highest possible output signal of the 192. 10k ohm 'ballpark' for the 192 and +23dBm output? Can anyone in support or engineering give me an 'exact' for these two values? Thanks for your help. audiomark |
Re: Reflected Impedance & Highest Output Level, 192?
If think this information is crucial to your operation (why?) then it would be a fairly straightforward to measure this for yourself by using a low impedance output signal generator and a few large value resistors of known value and a piece of graph paper and a pencil. You would also be able to measure the frequency dependency of the input impedance. Why are you asking about the "reflected' input impedance as this is only of interest in transmission lines and an audio balanced input is certainly not a transmission line.
Clipping can be measured with a distortion meter and votmeter- an oscilloscope would also be usefull. Why on earth is the exact value of any great importance? |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
003 output impedance conversion | Marvin the android | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-15-2010 07:50 AM |
Changing a mic level signal into a guitar level signal with correct impedance | mgnyhc1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-22-2009 11:15 AM |
882/20 Output Impedance??? | TAGS | Pro Tools TDM Systems (Mac) | 2 | 08-13-2004 12:52 PM |
SOS:How to get the highest vocal level with ProTools. | Earjam | Tips & Tricks | 15 | 09-25-2000 07:19 AM |
