Re: Cannot change clock source
Never had that issue, just set the onboard as the default device and default communication device and that's it.
What worked for me after trying all the other suggestions: temporarily change your playback engine away from your 003 (or whatever) interface - in my case I told Pro Tools to use ASIO4ALL via Setup | Playback Engine. After a PT restart, switch the playback engine back to whatever you have the ADAT plugged in to. Suddenly I could now finally change the clock source to ADAT.
If your track i/o is set for ADAT channels you may find them deactivated. I reassigned tracks temporarily to Analog sources, then I could switch them back to the magically reactivated ADAT channels. PT 11.3.2, Digi 003, Windows 10 Pro |
@Thistlefarmer, glad to hear you figured out a solution. I'm on PT12 but I'm going to give what you suggested below a shot. Thanks for posting your method.
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Problem detected with audio clock. Check clock source and sample rate are correct | mongrel8686 | Third Party Interfaces | 11 | 08-01-2013 08:42 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
problem detected with audio clock. check that your clock source and sample rate are c | angeleda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2010 07:09 PM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
