Faders gone crazy
A question for the almighty oracle:
I have a Digi 002 that has worked flawlessly for the last year, except that when I moved to a new apartment - the faders started locking up. They get into the right positions during sessions and move like they are supposed to, but I can't move the faders manually. The faders will not budge unless I put my fingers on *all* the faders at once. The less faders I touch, the less they budge. In standalone mode, during "fader touch test" - the red lights above "select" blink randomly when I touch the faders, and show the same behavior. So, it looks like some erratic fader group error. The answerbase suggested it might be a power issue. Is this the case? - Morgan Page http://www.nuancerecordings.com |
Re: Faders gone crazy
Just recently tried plugging the power cord into different power strips and outlets -- no luck..
Anyone out there? - Morgan |
I remember a post about a year ago about a guy who had the same issue in the basement but it worked on the second floor.
Get an outlet tester (a few bucks at a hardware store) Plug it in and make sure the polarity is correct and the ground is working properly. |
OK - thanks for the heads up, will give that a try.
I've plugged the 002 into both of my power conditioned strips, a regular power strip, and directly into the wall outlet.. The strange thing is that the new apartment has newer electrical wiring than the last, and the last place worked fine. - Morgan |
Newer biulding have the nuetral and the ground seperated at the box. Older homes do not have that setup so it is possible you had a problem before but it did not show up untill now.
2.7.1 - Mix window faders & MC Mix faders ? | priorytools | Artist Series | 2 | 05-14-2013 02:37 PM |
Custom Faders moves position of all other faders!?! | freeBase | ICON & C|24 | 5 | 02-26-2009 06:44 PM |
A CRAZY, CRAZY MOMENT WITH MY C24 | quanahtx | ICON & C|24 | 4 | 05-26-2008 02:59 PM |
Faders Going Crazy On 002 | christavile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-10-2006 07:49 PM |
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... | domsound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-08-2004 07:06 PM |
