Audio track monitoring of aux is completely broken for me [solved]
***SOLVED***
Hi.. Having major issues with that here.. it only became important for rewire on aux, when i wanted to record to audio in realtime, or monitoring virtual loopback instruments.. It just doesn't work. To do the simplest of tests... Create an AUX track.... put a Vi on it. Create a midi track. Record some midi. Set the output to aux 1 or a bus or whatever. Now, create an audio track. Set input to the output of the VI aux track. Hit record. Press play. You don't hear anything, but when you *stop* playback, you hear a couple notes. That's it. No matter what VI. No matter what rewire. BUT - if you actually record the track, i/e hit command space and let it play through, suddenly it monitors perfect and *correctly records the audio* !! Surely this is a bug? Anyone else can confirm please? Core audio PT vanilla. Any buffer size.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX Last edited by TNM; 02-06-2018 at 05:34 AM. Reason: Solved |
Re: Audio track monitoring of aux is completely broken for me
That's weird,
I don't have the iLok in my studio right now, as it's at my brother's studio. But will try out as soon as I can. I remember something about doing it the same way you did but worked ok.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
If I'm correct you need to turn input monitoring on when you want to monitor the input of an audio track while not in recording regardless of the source. This how you hear what's being recorded or hear what's recorded on the audio track itself.
This is also part of the way I set up my analog summing / ITB mix in PT. I print the output of the mix bus to a audio track (print track). I have to monitor as I mix so I turn input monitoring on (it's on by default in my template). Once I print my mix I can turn input monitoring off to preview the recorded mix as well as you can make new playlist for different revisions of the mix.
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. |
ahh of course.. i keep watching tutorials Pre Input monitoring being available in vanilla.
That fixed it.. will edit the OP.. THANKS! i feel like a total dunce over this one.. maybe my brain just too tired right now thanks again, much appreciated Edit, hmm, there doesn't seem any way to edit the actual title. Is that possible?
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
Select your track(s) and option+k to toggle input monitoring on and off in Vanilla Pro Tools.
What is more relaxing than Music? Pro Tools Carbon for macOS 12.7.4 My HDX for Windows11. Gigabyte Z490 Vision D - BIOS F21b Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1) Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity Bricasti M7 (2) Lexicon PCM96 Neumann KH805 - KH310 Yamaha NS-10M Avantone Mixcubes Grace Design M905 Etc, etc, etc. Last edited by abc1mce2; 02-06-2018 at 06:02 AM. |
Marked solved and locked.
Track Input Monitoring 10.3.9 HD broken ? | modulo2008 | Pro Tools 10 | 271 | 11-22-2016 07:33 PM |
Core Audio has been broken forever.. completely fed up!! | luts | macOS | 5 | 12-19-2012 11:00 AM |
On a stereo audio track, the left track is completely dead | ckwhy2008 | Pro Tools M-Powered (Mac) | 1 | 04-09-2011 04:16 AM |
Pro Tools is completely broken.... :op | WATYF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-27-2005 10:02 PM |
