  #31
Old 07-25-2017, 10:32 AM
EddieJones's Avatar
Default Re: 16 Softkeys not active
Great thanks for the info. Not sure why your Automation buttons aren't working though ;-/
  #32
Old 07-25-2017, 10:48 AM
EddieJones's Avatar
One more question....when does this break:
If you start with PT focused and locked to the whole surface and the 16 Softkeys working, then focus safari. Are the keys still lit now ? Or do they break when you focus back to PT ?
  #33
Old 07-25-2017, 01:11 PM
Moviesound Moviesound is offline
It breaks straight away. As soon as you leave pro tools. I.e. Every time I click on finder, Safari,RX you name it
  #34
Old 07-25-2017, 05:14 PM
mattrixx mattrixx is offline
Same here. Also of note, if ProTools is not locked to Eucon (under the assign tab), the soft key LEDs will stay lit, when you say, click in the Finder and then go black on clicking back in ProTools and bringing it front most.
Where as if Pro Tools is locked to Eucon, they go black instantly when clicking in the Finder.
Quirky!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
  #35
Old 07-26-2017, 04:48 AM
SteSo SteSo is offline
Hi Eddy,
just some things you shouldnīt forget about this.
Itīs not only that the Softkeys stop working by changing the application, but also by other actions in the app as there are e.g.
-new track
-hide track
-show track
-switch on/of another controller (in my case Artist Mix)
and some other tasks. I remember another post (but I donīt find it quick enough), where some more things were listed.
To answer your questions, itīs as moviesound said. The buttons on the ipad are still working, all other keys beside the Softkeys on the dock, too. And in my case the automation buttons do all work as they should (for me really important).
One thing about my experience with that was, when I first installed the Dock, I was running EU-Control that was setup with the Artist Control. In this setup lotīs of keys of the dock didnīt work as expected. Then I installed the `factoryīappset from avid and everything was fine.
One interesting point is, if I switch between PT and EU-Control the Softkeys donīt loose their function.
And one other point out of this context; I canīt give color codes I want to the right Edit Switches. They just take yellow, green and red. But thatīs really of no primary importance.
Cheers
running PT11.3.2, OS Yosemite, EUC 3.6.1, MacPro 5.1 12Core
  #36
Old 07-26-2017, 06:28 AM
Just to confirm..I'm getting exactly the same issues as SteSo
  #37
Old 08-31-2017, 07:23 PM
Just checking in Eddie Jones, on when we might see a a Eucon update to fix this and the other issue of the right side button lights disappearing when we touch the right side touch strip??
Matt McKenzie-Smith
mattrixx.net
  #38
Old 08-31-2017, 07:39 PM
EddieJones's Avatar
We are working on this for the next release later this year. Once we have a fix and a beta version I can let you guys test it. (I just checked and these are due to be worked on starting Monday, so hopefully some news soon)
  #39
Old 08-31-2017, 07:52 PM
Thanks Eddie. I'm really looking forward to a fix for this.
Matt McKenzie-Smith
mattrixx.net
  #40
Old 09-11-2017, 01:31 AM
Any progress on this?
Softkeys are binded to macos tbov Artist Series 0 10-13-2016 08:06 AM
SoftKeys customizing - XML OvD Avid S1, S3, Dock and Control App 2 08-17-2016 02:32 AM
Softkeys dedicated to workstation Gregor B. Avid S4/S6 3 01-18-2016 12:09 PM
C|24 and PTHD softkeys fakir_cz ICON & C|24 4 12-01-2011 06:54 PM
Instrument track in-active, without making it in-active Ylle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2007 01:18 AM
