Old 09-18-2015, 04:07 PM
Alarry0829 Alarry0829 is offline
Default PT 12 Creates a hug temp file
Using pro tools 11 I didn't have to worry about temp files. I bought PT 12 and now I get between 5000 to 7000 temp files. WHY?
Old 09-18-2015, 04:08 PM
jclark5093 jclark5093 is offline
Default Re: PT 12 Creates a hug temp file
Is that how many files, or the size of the files? Where are they being created?
Old 09-18-2015, 04:10 PM
temp folder. when I clean my system with mcaffe
Old 09-18-2015, 04:12 PM
There is between 5000 to 7000 temp files, not the sizes of the files.
Old 09-18-2015, 04:13 PM
That is unlikely Pro Tool's problem... don't run crapware like McAfee.
https://www.youtube.com/watch?v=bKgf5PaBzyg
Old 09-18-2015, 04:15 PM
what do you use.
Old 09-18-2015, 04:25 PM
what do you use.
*Nothing* but common sense. Most actual malware/infection issues are caused by idiot users.
If you have to, use Microsoft defender or anything else besides McCafee. But nearly all this stuff is worse than much of the Malware out there. Turn it all off manually (as you are supposed to anyhow for Pro Tools). And only run it by hand if you need to check. And maintain a long-tail of archived backups/images copies offline that you can roll back to. None of this stuff provides particularity solid protection. A really solid backup plan is your best real protection against lots of issues.
If you have to handle lots of public files/media of questionable provenance then set up a sterile PC or virtual machine where you can examine this before moving to a production system.
Old 09-19-2015, 10:32 AM
The Weed's Avatar
The Weed The Weed is online now
And for a nice solution to imaging a Windows comp, try Macrium Reflect 6 Free.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
AVID MC creates illegal file names? Frank Kruse Post - Surround - Video 0 10-07-2014 09:26 AM
bouncing creates a higher pitch file MichelMazza Windows 5 05-02-2013 01:12 PM
Export temp Map as a Midi File RTASW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-17-2012 05:06 PM
How do you install the Pro Tools 8 .dlm file Download Manager creates? sciascia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-20-2009 09:20 PM
PTF creates one enormous file using whole HDD!!! nils Digidesign Hardware & Software 0 03-27-2001 11:32 PM
