Is there a solution for this?!?!?
When using UAD or any other DSP plugin, auditioning loops in workspace will not sync as there is no ADC.
I know you can re-route the audition path in the I/O settings but that doesn't help if your only using main outs 1&2. Is there a workaround here that I can use?
Musically yours, 6love Mac Pro5,1 2x2.24 12-Core, ATI HD5770, OSX 10.11, 16GB RAM Apollo Quad Firewire, UAD2 Solo & Quad NI Maschine v2 PT2018 |
Re: Is there a solution for this?!?!?
Anyone?
I don't know! It's a good question though. Maybe you can audition loops in structure or some other soft sampler with a UAD plugin on the track. I'm sure somebody out there knows a way to do it. They just need to step up!
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
Hello 6love,
UAD-2 users get a free Mellowmuse ATA Plugin , UAD-1 Users get a favourable discount this should solve your problems. Also ATA uses much less DSP power than PTHD ADC. http://www.uaudio.com/support/uad/rtas.html |
I'll give it a go though and see if it helps!
Thanks for the reply.
External DSP is NOT the CPU Solution Either...Please! | relaxo | Pro Tools TDM Systems (Mac) | 1 | 09-28-2009 03:44 PM |
Solution | abre | Pro Tools M-Powered (Win) | 0 | 10-02-2006 02:38 PM |
Best Solution for D/A in LE? | jes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-11-2004 08:01 PM |
Solution for you maybe? | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-01-2003 02:33 PM |
Does anyone know the solution? | Yoichi | Digidesign Hardware & Software | 1 | 10-19-1998 04:55 PM |
