  #31
Old 02-17-2022, 09:16 AM
Ben Wood Ben Wood is offline
Default Re: Does the Monitor Control Room knob on the Artist Control do anything?
Might be old news but the Monitor Control Room knob works on the Artist Mix
Im running Eucon 4.8.3.29.
Make a master fader, right click, click Eucon Monitor (at the bottom).
Cheers
  #32
Old 12-18-2023, 04:43 AM
Ru_C Ru_C is online now
Just picked up a used Artist Control & Omni, to upgrade my home/office setup.
First thing I assumed would work of course, was the 'Monitor Control Room' knob on the Artist Control, controlling the 'Monitor Control Room' function/knob on the Omni.
Does this really not work? Or am I using it wrong & need to rtfm more?
cheers
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
  #33
Old 12-18-2023, 10:29 AM
BScout BScout is offline
cheers
No. And never will. The Omni does not support Eucon so can't be controlled.
  #34
Old 01-08-2024, 09:56 AM
Cheers
Any kind of hack to stop the master fader going *above* 0db, when it keep turning it to the right?
It would essentially work as intended (In Pro Tools anyway), if I can achieve that.
  #35
Old 01-29-2024, 03:14 PM
Ok, I'm talking to myself now on this point (it comes to us all with old age), but is this a solution?
As I can't stop the Master fader from going to +12 when I turn the Artist Control Monitor knob fully clockwise, I've just put a trim plugin on the Master fader, & set it to -12db (-12.5 to be safe).
This basically seems to work, & I now have a functioning volume knob, that essentially hard-stops at '0 db'
Have I just found a workaround? or is there something horrible happening with floating-point vs fixed-point maths on outputs, that I don't understand?
For Kyle: Monitor / Control Room Knob Anthony_Anz Avid S1, S3, Dock and Control App 15 07-20-2017 10:37 AM
Artict Control Monitor/Control Room Knob & HD Omni DAWgEAR Artist Series 4 07-07-2014 01:56 PM
Artist Control Monitor/Ctrl Room Volume Knob HowlingWolfStudio Artist Series 1 04-15-2014 11:10 PM
Anyway to get visual feedback for the Monitor/Control Room level on the Artist Contro Focuret Artist Series 0 11-19-2012 11:46 AM
Euphonix MC Control V2 - Control room knob PT9HD-HELP hugoleitao Artist Series 3 06-09-2012 06:03 PM
