MDW installer ver 1.1 does not work properly
MDW installer ver 1.1 checks only to see if you have MDW in the plugs list, NOT the version or date. If you have ver 1.0, it reports that you do not need to update the plug-in. When you run PT, PT reports you have a plug-in that needs to be updated.
You have to remove MDW ver 1.0 from the plugs list before you run the installer if you want a proper update. |
Re: MDW installer ver 1.1 does not work properly
I had this same problem. Thanks for the tip. I never removed 1.0 before I ran the updater, and therefore could never get it change to 1.1. Messed with it for a while and gave up. I need the 1.1 though. That full-code blast has already taken out one set of monitors!!!
Todd Franklin, TN |
Eeeeyow! Sorry to hear about the monitors! Their death may have saved your ears, though!
I can't get my Mic to work properly | Djgman925 | macOS | 8 | 08-22-2013 01:53 PM |
Pro Tools installer disc will not launch properly on my system. | dostacks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 03-25-2010 11:51 AM |
AudioSuite does not work properly. | ali3 | Pro Tools M-Powered (Mac) | 2 | 04-15-2009 05:13 PM |
session doesn't work properly! | kppoykko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-31-2007 10:18 AM |
882 will not work properly with 888 | dwall | Pro Tools TDM Systems (Win) | 0 | 08-30-2007 12:20 PM |
