Old 02-23-2011, 07:57 PM
mzimpfer mzimpfer is offline
Default 11R Mic Input
Not much documentation in PT or 11R materials about mic input.
Regarding track creation is mono > audio the only way to go?
Any reason to create a stereo track for mic and if so is it possible with 11R?
Is there a mic modeler somewhere on LE?
Compression or effects while recording mic?
Any other mic thoughts would be welcomed.
Old 02-23-2011, 09:18 PM
adamqlw adamqlw is offline
Default Re: 11R Mic Input
The mic input is mono, just like the Guitar DI.
You can set the 11R input to mic, then record a stereo out from the 11R. There is no mic modeller, but in the upcoming expansion, there will be a studio quality compressor and some new effects. If you want to record a processed mic signal in stereo, this is the way to do it.
You cannot create a stereo track and set the source to mic input (unprocessed). To be fair, I don't understand why anybody would want to do this (record a dry mono source in stereo).
Old 02-23-2011, 09:25 PM
zedhed's Avatar
zedhed zedhed is offline
I think the mic input was originally created more for reamping rather than using it as a vocal mic.
It's my understanding that with the upcoming expansion pack this has been changed to help accomodate vocal recording as well.
Please correct me if I'm wrong.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 02-24-2011, 01:05 AM
bredo bredo is offline
A micpre is a micpre. To record whatever you want through a mic.
The coming software compressor and other effects are just like other software plugins.
Fine for mixing, but I'll never track/record vocals with software compressors and eq's etc. Always hardware for that kind of thing.
To record in stereo, you will of corse need 2 mics and 2 micpres into a stereo or dual mono tracks.
using HDMI input mutes line audio input of TV mr.armadillo Post - Surround - Video 15 09-24-2013 12:33 AM
MBox problem - bad hiss on 1/4" input, but XLR input is ok!(?) haney411 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-31-2008 10:22 AM
New to MIDI. Input is quantizing. Input Quantize is disabled LiamSlack MIDI 0 03-25-2008 08:59 PM
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-28-2003 04:08 PM
switch auto input and input only monitor with midiprotocol mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-27-2003 03:51 PM
