Singers and volume control
Heres the thing...
I record alot of singers and i always have trouble with controling their volume... when they go to hit a higher note it sounds kind of muffled and starts sounding like the person is yelling... Im not sure if i should try adjusting my preamp or protools.... My chain goes - AT4040 mic -> Summit audio B221 pre amp -> Protools Mbox2 pro.... and the plugins I have are Waves Musicians 2 any suggestions |
Re: Singers and volume control
are you using any compression on vocal tracks?
does your recording room sound good? do you leave enough headroom for the pre/PT?
How is the Summit patched into the interface?
RENASANCE compressor from waves musician 2 sometimes.... I havent mastered how to use it yet
I definately do...
Going from the XLR output of the Summit audio to the XLR input on the Mbox 2 pro
you should be going from the summit audio XLR>Balanced input 3 or 4.
you are going through the good (summit) pre and the digi also (booo). GET A MOGAMI XLR > BALANCED 1/4 and you will be much happier |
try this
set up an mono aux track pick your mic input and on that aux track put your compressor now bus that aux (pick a mono bus out then on the audio track make that bus the input)track to a audio track this way you can use your internal compressor to control your input signal this will work best with a very low buffer like 128 or 64 that should help i hope. |
Paulreed is correct. What you are doing is preamping twice here. The Summit should be plugged into a LINE input.
Help for singers! | oiselle | General Discussion | 0 | 09-12-2010 11:34 AM |
Best Microphone(s) for R&B Singers? | Scorpio253 | Tips & Tricks | 8 | 12-08-2007 10:23 PM |
OT- Singers and Chewing Gum!!! | superpenguin79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-13-2004 05:33 AM |
++ CALLING ALL SINGERS ++ | chonk | General Discussion | 4 | 10-13-2003 02:06 PM |
OT: Singers who can't sing | jtplayer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 40 | 11-07-2002 01:06 AM |
